My Mavic Pro is now a safety hazard because of your "updates"
12345678Next >
12187 299 2018-7-2
FrequentC
Flight distance : 158770 ft
I don't sit in the forums everyday, I have a job and lots of tech to keep on top of, I don't have time to go online before I fly my Mavic Pro and check to see if there are new bugs that make the unti UNSUABLE!  But i went to use it on a job yesterday ... and ... WTF DJI?!  My Mavic Pro is now a safety hazard because of your "updates"!! I can't see anything on the screen (and I'm part of a giant chours of android users complaining about this), and the drone just flys where-ever it feels like!?!??!?! ARE YOU SERSIOUS!?!??!?!?!?
I should have to come here to tell you to fix this because it NEVER SHOULD HAVE HAPPENED!!!
If any laywers are reading this, please tell me how to add my name to the class-action lawsuite that I'm most certinaly sure has started.
2018-7-2
Jannistmb
Flight distance : 516161 ft
Hey that sounds weird which mobile device are you using?what do you mean your drone flys what ever it wants?
2018-7-2
FrequentC
Jannistmb Posted at 2018-7-2 06:27
How does that "sound weird"? Sounds like a pretty common complaint .. or have you not looked at the reviews for the DJI Go4 app lately?
https://play.google.com/store/apps/details?id=dji.go.v4
2018-7-2
dvarapala
Flight distance : 94347 ft
Has DJI acknowledged that there are issues with 4.2.20 for Android? Have they announced when a fix will be released?
2018-7-2
FrequentC
I got this reply from support on Facebook:  " You can try to downgrade your DJI GO 4 APP. Uninstall your current app the try this version instead.  https://www.dropbox.com/s/j3b1w8hjphkln6n/4.2.16.apk?dl=0 "
2018-7-2
Flycaster
If, and when you do decide to do an update to anything, first rule is to test it, before waiting for the day of the job.
Other than that, yes, there is a problem/issue with the "updates" that are released from DJI.
Again, if you decide to go with an update for that "booberang" shot in the app, go for it, but be forewarned.
I have never updated anything in over 18 months of ownership, Rock solid.
But yeah, you can go ahead with the CA suit, but good luck on that one.
Best bet is to just bite the bullet, backrev, and then once is all right with the world, turn off all sync/updating in your tabby/phone/device.
Never power up your AC (make sure the props are off in case of an accidental spool up) at home with the wifi on, turn it off. That way you won't get "bit by the bugs"....
2018-7-2
FrequentC
Flycaster Posted at 2018-7-2 07:09
So what your saying is that DJI is an untrustworthy company that you suspect puts out bad product and we should take extreme precautions to avoid them?
2018-7-2
Jannistmb
FrequentC Posted at 2018-7-2 06:50
You are right about the app i had also many issues but only with android devices then i changed to ipad mini 4 and i have no issues so far.Sadly they dont support many android devices.But what about the mavic?Do you have issues flying the drone as well?
2018-7-2
Brad Bilger
Flight distance : 14843274 ft
This will probably upset a bunch of people out there, but I am running 4.2.20 on an Samsung running Android V 7.0 and I'm not having a single problem or flaw.  I've NEVER had a problem.  And I don't know why.  But I'm happy about it.
2018-7-2
FrequentC
Jannistmb Posted at 2018-7-2 07:42
It occasionally drifts well after I've let go of the joysticks. Tilting the gimbal drifts very often, very far as well
2018-7-2
Brad Bilger
FrequentC Posted at 2018-7-2 07:51
You are in the minority: https://play.google.com/store/apps/details?id=dji.go.v4
That's good....  Because I am not a Apple fan at all.
2018-7-2
Uax4It
Plug the Drone and Controller into the computer and refresh the update i am using galaxy s7 with no issues
2018-7-2
Jannistmb
FrequentC Posted at 2018-7-2 07:50
I had this problem as well and i did compass and IMU calibration and everything was back to normal again.Maybe you can gine it a try and i hope this will fix your issue
2018-7-2
QuadKid
Flight distance : 482349 ft
I'm pretty sure that all these updates for Android and IOS for that matter, is to keep up with the OS updates put out by Android & Apple. I use a Crystal Sky (Optimized Android) that doesn't receive OS updates unless put out by DJI and it is rock solid, well maybe slight video glitches @ 5000' away. Still using 4.1.16 App with P3P, P4P, MP & MA.
2018-7-2
FrequentC
QuadKid Posted at 2018-7-2 08:05
Let me  know how it goes when you need support for that product
2018-7-2
FrequentC
Uax4It Posted at 2018-7-2 07:58
The point I'm trying to make is that DJI keeps putting out buggy stuff.  Yes, it can usually be fixed if you sit around for hours trying to find solutions, trying them all, and praying one of them fixes it. But I should have to.  I also shouldn't find out my drone isn't working when it's in the sky and it worked "fairly" fine the last time I used it. (I say "fairly" because previous versions of the app would just randomly crash on occasion)
2018-7-2
Uax4It
FrequentC Posted at 2018-7-2 08:18
The only way to correct issues is to put out patches and updates i always plug my drone into the pc after use for diagnostic issues and calibrations .I just dont want to end up with a fly away or crash on a 1200 dollar drone better safe than sorry
2018-7-2
FrequentC
Uax4It Posted at 2018-7-2 08:33
Do you have a point?
2018-7-2
Uax4It
That is my point 10 mins of your time after use to run diagnostic and calibration make a person more confident before flight every pilot runs a check list before flight
2018-7-2
Uax4It
Uax4It Posted at 2018-7-2 08:42
You think you have issues i live in new jersey on the Hudson 2 miles from Manhattan most times i set my Mavic to fly it wont take off i get No Take Off No Fly Zone
2018-7-2
Uax4It
OK i did some research connect the phone to the controller turn on the drone click Reset Remote Calibration it will start to beep now push the reset pin in on the drone and you should be good to go
2018-7-2
hallmark007
Flight distance : 9827923 ft
Sorry it’s a bit confusing, you say your Mavic Pro is drifting and problems with gimbal which creates big drifting.
Yet you were going out to do some commercial work , with a faulty drone..
Any commercial pilot worth his salt just wouldn’t turn up for a job already knowing his craft was dodgy.
You say you couldn’t see anything on your device, was this at take off ?
You also would be far better off letting the forum know what firmware/software your on , maybe show some screen shots of the problem, you also have the option to roll back any updates if they are not working for you, as well as the option not to update.
I have been checking progress of 0300 on other forums and the consensus is that it is working very well. While I don’t have an android I cant speak for problems with this, but can say Crystalsky is working fine.
What is your set up, have you tried to change cable even just to eliminate, when was the last time your drone was working well ?
2018-7-2
dbparti024
Flight distance : 3343 ft
I just want to know exactly what version o fthe DJI Go app I should use, and what version level of firmware for the controller and MP. DJI show label what version  firmware is "Stable" and not force us to upgrade.  I no longer use the DJI Go app for now, because the video lag is beyond unacceptable.
I switched to the Litch appi, and the Video and interface is  run flawless. The only difference I see is that the photo's and video do not save to my phone or tablet. I see this as a good thing since I pull them of the SD card.
The problem is not our phones or tablets, if they work on Litchi, they should work on the Go app.
2018-7-2
HedgeTrimmer
Welcome to Beta Testers Club!
2018-7-2
FrequentC
hallmark007 Posted at 2018-7-2 09:14
Reread everything above and then ask yourself why you were so easily confused.
2018-7-2
dbparti024
HedgeTrimmer Posted at 2018-7-2 09:23
More like Alpha
2018-7-2
3-D
Flight distance : 635764 ft
FrequentC, I get your point.    You don't fly everyday, but when it's time to fly, you want to fly.  Here is my recommendation in that case.  Have a dedicated device that doesn't update automatically.  That way, there will be no changes unless you initiate them.
After the first time I had an went out and wanted to fly and got hit with a firmware update request, I stopped it from autochecking, and made sure that the device (Galaxy Note4 edge) does not connect to internet in any form or fashion unless I want it to.
You are correct.  You shouldn't have to do a lot to make it fly.   So going forward,  you should find a version of the app that works for you.  And stay there.  if you find that there are issues, or if you find out that there is a new feature that you want/need, that's when you look at the reviews for the new version and see if the risk is worth the reward.
2018-7-2
HedgeTrimmer
dbparti024 Posted at 2018-7-2 09:18
I believe people having problems with GO-4 app have rolled back to DJI GO 4 version 4.2.12 - when possible.  Their SmartDevice's OS level may not work with .12.
DJI GO 4 App Version History and Changelog:
2018-7-2
HedgeTrimmer
3-D Posted at 2018-7-2 09:57
I would add, make sure Firmware can be rolled back, should there be any problem with latest Firmware.  If it can't be rolled back, be sure you have enough time to secure a replacement should latest Firmware induce problems.
Something we should not have to do, but DJI has thrust that issue upon us.
2018-7-2
FrequentC
When they change this page, that's when I'll change how I use the drone:  https://www.dji.com/mavic/info
REQUIREMENTS:
Mobile App        DJI GO 4
Latency        160-170ms (depending on conditions and mobile device)
Required Operating Systems:
iOS 9.0 or later
Android 4.1.2 or later
Until then I will hold DJI accountable for what they say. And you should too.
2018-7-2
hallmark007
FrequentC Posted at 2018-7-2 09:46
As I said, you said you were going to do a job knowing you had a faulty drone, it’s fairly simple.
2018-7-2
3-D
FrequentC Posted at 2018-7-2 10:14
REQUIREMENTS:
Oh, do trust... we hold them accountable.  We let them know when they are wrong.  Not just in this forum, but with service tickets, and calls to customer service.  And we've been very vocal on the support (or lack thereof) for the DJI Go 4 app.    We also have known that the best way to work around this issue is to downgrade.  If it is possible for you to do this, then you should.  That is the option for right now.  This forum is much more effective when used as community outreach.  In terms of actual DJI support, or even true and meaningful acknowledgement, you won't find it here.  You'll find a bunch of average joe's like me, that are just looking to learn more and help others when I can.  You'll find the admins to be helpful in actually finding further information if you already have a case open, but should be considered 1st level support.  They are limited in what they can do.
You shouldn't change the way you fly.  Just the way you update your applications.  If you find a version that works, you should make a concerted effort to stay there.  That way, when you want to fly, you can fly.
2018-7-2
davidmartingraf
Flight distance : 106566408 ft
I have the issue and I'm using a Samsung Galaxy S7 Android v7.0 Nougat that has 4GB RAM?
Ever since the upgrade to DJI GO 4 v4.2.20 - I have had choppy video that makes it hard to fly.
2018-7-2
FrequentC
hallmark007 Posted at 2018-7-2 10:34
No. That's what YOU said.  You're taking parts of what I said out of context and making up a new version of events.
2018-7-2
hallmark007
FrequentC Posted at 2018-7-2 10:53
Read post 10 you said it not me, should we not read all thread before commenting, your first post only explained what new occurrence you had.
2018-7-2
Numero 5
Flight distance : 1385702 ft
The problem is that we don't have any official response from DJI, a lot of android users are complaining and they don't answer to our complaints... I don't want to roll back to an older version, wtf I want that DJI fix this issue. IOS received 2 new upgrades, but android version is stopped to a buggy version (laggy live video feed which is not a so minor bug...)
2018-7-2
Numero 5
Maybe we could raise some money to buy more android devices to DJI engineers for testing GO App........
2018-7-2
FrequentC
hallmark007 Posted at 2018-7-2 11:04
I'm fairly certain you're just trolling (or drunk) so I'm done responding to you.
2018-7-2
FrequentC
Numero 5 Posted at 2018-7-2 11:10
I'm pretty sure they can afford their own devices if they can afford this new head-quarters: https://www.digitaltrends.com/cool-tech/dji-new-headquarters/
2018-7-2
hallmark007
FrequentC Posted at 2018-7-2 11:31
Sorry I didn’t understand that you were only looking for people to agree with your rant, some people come here for help.
I see anyone who disagrees with you get the same treatment. So I’ll be gone good luck with your rant.
2018-7-2
12345678Next >
