SRQ-FL
Flight distance : 69639 ft
I have been having similar Aircraft Disconnect issue w/Mavic Pro this past week. I am using DJI Crystal Sky + DJI mount that has built-in cable that connects to thebig USB port atthe botom of the controller. I had been using this setup for the bast 6-7 months w/no issue until lately.
For me to replace the cable, I need to buy a complete adapter w/builtin cable.
If it is a cable issue, why is the problem intermittent. In my case, when I get the "Aircraft Disconnected" message, I can reconnect by turning off/on the remote controller. This will establish connection withthe GO4 app. This tells me that the issue is not the cable.
Also, I have noticed two modes of disconnections. If I unplug the USB cable from the remote, the GO4 app reports "Disconnected". In the other mode, the GO4 app reports "Aircraft Disconnected"
So, my guess is if you get just "Disconnected" message, then it is possibly cable related. If you get "Aircraft Disconnected", then there is another issue (possible software/firmware related) |
