Mavic Pro, Gimbal rubber bands
10221 13 2018-7-4
OwlPic
Flight distance : 26 ft
For some reason not related to any crashes or any other reason I can figure out, the rubber bands mounting of the gimbal have stretched.
The symptom is that the gimbal will not calibrate. On Startup it goes through its routine but banging into all the sides eventually ends up looking down and not functioning.
When do you start up with the mavic pro upside down the gimbal will calibrate and work properly once turned over.
We just bought the replacement Gimbal plate on Amazon for $20 and you can see clearly that the new rubber bands have almost no stretch at all to them.
Anyone else had experienced in this area?
2018-7-4
Mgozer
Switzerland
Have you already checked if the gimbal plate is actually below the metal "hook"?
2018-7-4
OwlPic
Mgozer Posted at 2018-7-4 03:52
Have you already checked if the gimbal plate is actually below the metal "hook"?[view_image]
Stretched vs. Unstretched rubber band
2018-7-4
OwlPic
OwlPic Posted at 2018-7-4 04:19
Doesn't look like much but stretched one hardly has any pull
2018-7-4
OwlPic
OwlPic Posted at 2018-7-4 04:20
Shortest video I could find on how to take the gimbal out. Hoping I don't have to do this but I will if I have to.
https://youtu.be/Sct5z2pTXpg
I have all kinds of small tools and I've been practicing replacing just the rubber bands on the gimbal plate I got. (I bought two $20 plates, one to practice on)
2018-7-4
OwlPic
OwlPic Posted at 2018-7-4 04:31
well I took it all apart.
I'm convinced that it could be done with tweezers, you need to squeeze the piece, insert it through the hole and let go. you need very fine tweezers with no serrations on the  inside , which I have ... just couldn't get it to stick.
Recommend buying the $12 mavoc toolkit from Amazon, It is just for the mavic.
Was able to do it with only unplugging connectors no ungluing / regluing.
The video above was very useful.
I used series of magnets and a paper diagram sitting on a steel plate so I could be sure I kept all the screws straight.
The magnet attached to the screwdriver insured the screws could be self-starting.
Took about 45 minutes, could do it again in 5 minutes now that I know what I'm doing.
A couple of details that give you pause because they don't come apart is easy as you think and you don't want to break it
2018-7-4
OwlPic
It's clear why the rubber bands are all stretched out. The weight of the gimbal is quite heavy compared to the tiny rubber bands. I guess you're supposed to store it with the back of the copter down, bellyup?
2018-7-4
OwlPic
2018-7-4
OwlPic
Well the gimbal works fine now doesn't slap into the walls hangs freely. Video is perfect. But it won't calibrate, go through startup routine fine just off axis
2018-7-4
OwlPic
Guess I'll be putting the gimbal lock on from now on.
2018-7-4
OwlPic
Turns out, in addition, have a broken cable. You Can see why. The gimbal start-up sequence, stretches the cable against a sharp edge. This puts a notch into the edge of the cable, that eventually grows to be a crack. Only had about 30 flights, but lot more bench turn ons, while learning the software.
Looks like will be replacing cables every so often.
Going to try to file off the sharp edge and put a tiny drop of hard-coat nail-polish on the ribbon's edge.
2018-7-7
bandicoot
Same exact thing happened to me (no crashes ~30 flights).  Long time flyer, bought a mavic pro and quite disappointed that everything is now useless due to some rubber bands.
2019-9-4
fansb7509844
Hi - if my gimbal is somehow got on top of the metal hook, how do I get it back under?
2020-7-18
Mgozer
Austria
It happened to me also.
I just had to slowly and firmly slide the bracket forward.
I have to tell you that I was scaried a lot, but in the end, it worked.
2020-7-28
