paul2660
Flight distance : 10331 ft
Labroides Posted at 2018-7-5 15:58
Before you chastise him too much, be aware that currently many folks can't get the flight data off the P4 Vr 2.0 or the Plus version, which IMO would be even harder.
But that's irrelevant to using the flight data recorded by the app as was suggested several times to the OP.
Assistant 2 if you are using a iOS device IMO is still a much faster method to get any data off the drone. As I understand it the .DAT on the drone has more info than the .DAT on the iOS device. To get to that data you have to use iTunes, and IMO that process has always been a mess, i.e. getting data off a iOS device, either phone or tablet. I understand the process, but it's just not that clear cut.
Assistant 2, when it works, you just browse the drone and pull the file.
Paul C |
