Reset all settings
76255 20 2018-7-4
LeftHandMedia
Flight distance : 226713 ft
Can anyone point me in the direction of setting the ronin s back to factory settings?
TIA
2018-7-4
Yes, please tap the Restore Gimbal Settings in Settings. Here is the screenshot for your reference. GTScreenshot_20180705_182003.png
2018-7-5
joaosantiago
Brazil
Hello I'm very frustrated, because when I was using my ronin for the second time, something went wrong. When I was doing the auto tune something happened and my ronin engine does not seem to work anymore. It turns on all the lights but the stabilizer seems to be dead. I can connect it in bluethoot but when I try to do any action through the app I get the message "fail". What should I do?
I really need to use ronin to work.
2018-10-26
joaosantiago
Brazil
2018-10-26
joaosantiago
Brazil
joaosantiago Posted at 2018-10-26 06:27
I solve the problem. I just update de firmware and now is ok
2018-10-26
djiuser_obTa0pzdBoBG
Morocco
joaosantiago Posted at 2018-10-26 06:24
Hello community
I just wanna know if there is any way to factory reset the ronin s beacause i did a calibration to the axis from the app and it didn’t go well. So i m just wondering if i can can recover factory setting.
2019-4-22
djiuser_obTa0pzdBoBG Posted at 4-22 07:37
Hello community
Hi there, as I posted in 2#,  Restore Gimbal Settings can be selected in Settings via the APP and there is also System Calibration you may have a try.
2019-4-22
djiuser_m41jx987R8ci
Estonia
Hi!
If i want to do the factory settings reset.. do i need to do it while my camera is on the gimbal? I didn't find any instructions about it.
2019-5-15
djiuser_m41jx987R8ci Posted at 5-15 10:01
Hi!
Hi there, sure, the camera must be installed in the gimbal and balanced well, then you can restore the gimbal setup via the APP.
2019-5-16
djiuser_os7XpHU1CJNC
Argentina
Hola, tengo el problema con mi ronin-s que el botón desencadenar, q es el gatillo de adelante, no me está respondiendo y antes lo hacía. No se q configuración toque que ahora no responde.
2019-6-23
NaylaDib
Argentina
I have stopped working the button called "button trigger" located in the front. How can I make it work again?
2019-6-24
NaylaDib
Argentina
NaylaDib Posted at 6-24 16:16
2019-6-24
aaapoc
Hi all. Restore Gimbal Setup doesn't seem to reset my Ronin S to factory default settings. The app is definitely connected to the device, and I have the latest app version and firmware update.  Any advice?
Edit: System Calibration also does not do anything.
2019-7-5
djiuser_BPj0imMqECZo
Japan
Hi!
I have problem?I set the my camer in dji robin s.but it’s not correct mood how to do set the my camera.pleace tell me solutions
2019-7-14
djiuser_3glU3AUHJ2O1
Hi, i havent used my Dji Ronin S in months & i forgot the passcode to connect the gimbal to the App. Anyway i could reset that passcode?
2020-5-22
fans2f62581e
Philippines
DJI Mindy Posted at 2018-7-5 02:22
Yes, please tap the Restore Gimbal Settings in Settings. Here is the screenshot for your reference.[view_image]
Hi, how about for Ronin SC. I believe they don't have the same menu.
Thanks
2020-11-26
djiuser_eNpNmWDBKhSn
Indonesia
what does it mean when the light on mode is red?
And light in mode 2 off
2021-8-11
djiuser_raE5emumJGgA
Indonesia
i'm desperate with my ronin sc.. i don't know why the indicator light on menu 123 is red.. someone please help me
2021-11-29
fans3caa80ba
Indonesia
I’ve got the same problem, any solution?
2022-4-19
fans170685c9
Vietnam
I am second user ronin rs2 . Now i cant connect from my iphone with gimbal. Please tell me how to reset gimbal. Thanks
2022-12-27
djiuser_SG4aZwFobENx
Tengo el mismo problema y no existe ninguna información. Restaurar desde la app nNO FUNCIONA EN ABSOLUTO. I have the same problem and there is no information. Restore from the app DOES NOT WORK AT ALL.
2023-2-14
