Phantom 3 Standard - Unable to focus
2768 13 2018-7-5
Cotmcleod
Greetings fellow Droners
Have been searching online for the last few days, as well as spent nearly 2 hours messing around with my drone but have been unable to address this issue. Since I purchased this drone I have been relatively unimpressed with its image quality but figured that was the price I paid for going with an entry level model. However, over the past few weeks I have started to look at others results from the P3S and found their results leaps and bounds beyond what I have been getting from a sharpness standpoint. At this point for my last 2 flights I have been trying to play with focus but have been unable to focus the camera. I am unsure as to my DJI go app version on my second to last flight but upgraded the app to 3.1.42 (DJI Go- For Products before P4) for android on the second flight. In both flights the image was blurry and i was unable to get the camera to focus. Tapping on various areas of the screen showed the AE yellow circle and would adjust settings to expose that area properly but never focuses on that area. From what I am seeing online there should be a button next to the AE button labeled AF/MF (image below is not mine). It emberassing but I have to admit that i do not recall ever seeing this option since I bought the drone
However, at this point the AF/MF button is nowhere to be found. The only recent post on the forum in reference to this issue was resolved by going to the general settings area and enabling manual focus. However, when I go to general settings the Enable Manual Focusing option is nowhere to be found. I have dug into ever menu when connected to the drone and cannot find it burried anywhere (not from lack of trying, i burned half a battery digging around and never even left the ground). I have even gone so far as to completely remove the app and cached data before reinstalling with no change. My drone is also running the latest firmware and reports no issues. This issue makes it pretty much unnusable if you want to take photos or video and I think that this issue has been present from day one, resuling in the lackluster image sharpness. Does anyone have any ideas or suggestions? Thanks in advance
2018-7-5
DJI Natalia
Hi Cotmcleod, we deeply apologize for the inconvenience this have brought you. The image below is for DJI Go 4 App. Per the post you have, you said that you have the latest firmware, is it v01.09.0200? If not, please download the latest firmware at https://www.dji.com/phantom-3-standard/info#downloads and update the aircraft. You can also try to reset the camera settings on the DJI Go App. Hope this helps.
2018-7-5
Cotmcleod
Natalia, Doesn't the drone/app automatically let you know if there is a firmware update available? Via the Go app my drone firmware states "latest". If it needs to be done manually I will give that a shot. I have also reset the camera settings in the app with no change.
2018-7-5
DJI Natalia
Cotmcleod Posted at 2018-7-5 09:34
I believe you are connected to the remote controller's WiFi and doesn't have any internet access to check if it has the latest firmware. Please manually check by doing the steps below:
Turn on the aircraft and the controller
Connect the phone or tablet you use with your Phantom
Launch the DJI GO app.
Enter Camera view.
Tap the settings icon on the top right hand corner of the screen (indicated by three horizontal lines)
Scroll right to the bottom of the list of options and select ‘About’. You will be shown the current firmware versions of your aircraft and remote.
2018-7-5
Eric13
Flight distance : 13982031 ft
You cant focus on the P3S. It has a fixed focus lens set to infinity.
If you have images that are out of focus, you may have a camera problem.
2018-7-5
WD9EON
Flight distance : 686886 ft
Just a thought, it's been two years since I purchased my P3S, I don't remember if there is a protective plastic covering on the lens or not.  If there is, it should be removed.  Check closely as it will be clear and hard to see.  If it is there it should come off easly.
2018-7-5
Cotmcleod
Eric13 Posted at 2018-7-5 11:54
Eric,
That would make perfect sense as to what I am seeing. Unfortunately that would mean that the thing has been defective since I bought it. Further unfortunate is that I live in Northern MN and bought it right at the start of winter. That coupled with some busy stuff in my personal life meant that this drone has only been flown about 10 times in the year I have owned it. I guess its probably out of warranty and that I am SOL on this correct?
2018-7-5
RedHotPoker
Flight distance : 165105 ft
Cotmcleod Posted at 2018-7-5 13:16
Eric,
If it has fault, you can still send it in for analasys and subsequent repair.
RedHotPoker
2018-7-5
Eric13
Eric,
Not sure what the warranty says for the P3S.
DJI gives different warranty periods for the parts of a drone: 1/2 a year for batteries, 1 year for the body. Not sure about the camera.
Have you checked the lens very close? Maybe you stored the drone somewhere where humidity might have affected the lens?
But if you say it was from the beginning then I would file a repair request (warranty claim):
https://repair.dji.com
Take some photos at sunlight with contrast and details you can provide along with the repair request.
Before they send you a repair ticket you somehow have to prove you have an issue (at least that's how I remember it)
I sent mine in due to the famous tilted horizon issue last year.
When repair got back to me they said they can't see any issue in the photos I provided! (see below)
Ha, Ha, - there are some real funny guys at DJI repair :-)
Good luck!
2018-7-5
Eric13
Eric,
I forgot to add:
If you send it in be prepared for being send a refurb.
It's not guaranteed you get your drone repaired!
2018-7-5
Cotmcleod
Eric13 Posted at 2018-7-5 13:48
I forgot to add:
Eric,
I appreciate your time and information and will do what you have suggested. The good think is that I have pictures from some of the first flights with the dates in the EXIF. So those should show picture quality was poor right from the start.
2018-7-5
Geebax
Cotmcleod Posted at 2018-7-5 14:23
Eric,
Not only is your P3 Standard unable to change focus, it will not focus at all in a situation like that shown in you photo. It does not focus up close. Get it up in the air 60 feet or so and take a shot, that will tell you whether it is in focus or not.
2018-7-5
Peterx
Flight distance : 1499708 ft
Turkey
Normally the P3S does mpt transmit the feed in HD,but on transmit statis you see the HD symbol with the bars. Stop and restart the App so the HD does not   pops up.
2018-7-10
ALABAMA
Flight distance : 10442687 ft
The P3S has a no frills camera.  If you want superior results, upgrade to the 4 series.
2018-7-10
