KedDK
Flight distance : 1133038 ft
Denmark
paul2660 Posted at 2018-7-8 03:03
If a different card doesn't work, or a reformat of current card (128GB may not be support on some Phantoms), need to check the FAQ, you can also try resetting the camera in the Phantom. Do this via the camera settings tab, should be towards the bottom.
Also make sure you format the card in the drone. I have a lot of problem with DJI products Mavic, Spark and Phantom, with cards that were not formatted in the drone, instead via windows or mac, mac being worse.
The P4A and P4P support 128GB cards. As the pictures was present the card and filesystem seem to be working, most likely the card is simply not up to the task of film recordings. |
