Juus
Switzerland
DJI Tony Posted at 2018-7-8 06:32
Hi, sorry for the late response, do you have another SD card that you can use to re-update the aircraft? Please ensure that there are no files in the SD card aside from the firmware of the drone and would it be possible if you can provide the screen-shot of the current firmware of your aircraft using the DJI GO app under "About"?
Hey
i tried with two different sd cards, with mac and with pc.
when i put on 1.11 the drone starts the update but fail after about 2 min.
if i try to do it with an other update (1.10 1.9.... ) nothing happen.
i tried with the debug file, didnt work out.
i updatet from version 1.6 to 1.11 directly, that was a bad i dea i gues....
is there a file to totaly reset the firmware? |
