Greenish blur at map
625 8 2018-7-6
Toelis
Hello, I'm new with Phantom 4 Advanced. Untill now I flew with a Phantom 3 Advanced.
Today my first flight and I noticed two problems.
-Gimbal motor overload end a very unstable camera.
Home someone has the solution :-))
2018-7-6
DJI Gamora
Hi thanks for reaching DJI Forum, we do apologize if you are having issues with your DJI Phantom 4 Advanced. May we ask if you already updated the firmware of your aircraft?
2018-7-6
Toelis
Yes, I updated it before the flight. At start it controls the firmware version and thats OK.
2018-7-6
Aardvark
Flight distance : 384432 ft
If you zoom out on the map, does the greenish blur become a greenish circle, as used by DJI to denote restricted airspace ?
2018-7-6
KedDK
Flight distance : 1133038 ft
Denmark
You're in some warning zone, check the maps on the flysafe pages.
This is a PitA and DJI should make it possible to turn it off, luckily for you it seem that you're in no overlapping zones.
2018-7-6
KedDK
Denmark
The Gimbal problem sounds like a need for repair, you could try to check the flat cable connections going to the gimbal.
2018-7-6
Toelis
Aardvark Posted at 2018-7-6 08:28
Yes it does
2018-7-6
Aardvark
Do you have any filters attached to camera ?
2018-7-6
Toelis
Aardvark Posted at 2018-7-6 11:54
Nope, no filters
2018-7-6
