topher76
Issue: Propeller not coming off.
Background: My friend was landing the Mavic Pro on a field with tall grass. I wanted to put a sturdy, flattened bag under it to give it somewhere flat to land. As it descended in auto-land/rth mode, I went to put the bag on the ground where it would land. Unfortunately, the Mavic did not pause before making the final landing even though it usually does pause. So the Mavic came down before I could get the bag positioned, and the drone and its blades crashed into the side of the bag. Afterward, I noticed that the front-left propeller was damaged. I went to remove the damaged prop, but it seems to be jammed. I checked the other three props. On those, I can push down and rotate and remove them, but with the damaged front-left prop I cannot press down on the prop at all. It is jammed such that I cannot press it down before rotating.
Help! Does anyone know of a way to fix this? Should I spray some lubricant in there, like WD-40? Is there a tool I can use to help remove it safely? Do I need to send it in and pay a ton of money to have it repaired?
Thanks in advance!
