DJI Phantom series multifunctional backpack- - Paint outer Plate?
931 9 2018-7-6
snowyowl
Flight distance : 6119 ft
I just purchased the DJI Phantom series multifunctional backpack, and I was wondering if anyone here has painted the hard removable outer plate?I'm considering painting this outer plate but not sure which paints would stick to this plastic and I would like to achieve an outer glossy look clear coat.
I created in photoshop 2 variants of how I would like my end result.
Thanks,
-Josh
2018-7-6
RedHotPoker
Flight distance : 165105 ft
Looks great. I prefer fluorescent colours, but the second one appeals to my eyes best.
Not sure which paint would be your optimal choice.
RedHotPoker
2018-7-6
DJI Stephen
Hi. Thank you for sharing this thread with us. The DJI Phantom series multifunctional backpack on the right side looks great me as well.
2018-7-6
snowyowl
So, it seems that I have found a solution to my own question
I figured I would share the method I found to achieve these results I’m going to purchase the material and when I paint the outer shell I will post pictures and update this thread.
Steps:
  • You want to start by spraying the outer shell with a black base paint
  • next you want to either toss some Pearl powders which you could pick up from KP pigments or you can simply search on Amazon for Pearl Ex  Powdered pigments pack. A quick note regarding the Pearl ex this is a paint form meaning it’s not powered so you will have to use a small brush to color blend. Opposed to the straight Pearl powder which you can simply toss onto the black base paint no brush required.
  • If you’re using the Pearl powders blow off any excess clumps.Otherwise Skip this step if you are using Pearl Ex  Powdered pigments
  • Lastly you will want to put a clearcoat you can use Rust oleum specialty triple thick glaze or you can use Krylon crystal clear glaze I would spray three coats
This method can be used for painting just about anything plastic. Hope this has been useful.
2018-7-6
snowyowl
Fyi Hobby Lobby Sells what you need, and so does Michael's
2018-7-6
RedHotPoker
snowyowl Posted at 2018-7-6 12:29
I look forward, only because my eyes are in the front. Hahaha
But I will be checking back here, for your creativity and skills.
RedHotPoker
2018-7-6
RedHotPoker
snowyowl Posted at 2018-7-6 12:19
Thanks, that is how I would do it... grin
RedHotPoker
2018-7-6
KedDK
Flight distance : 1133038 ft
Denmark
Looking nice but if you're going to paint it, better make it light/bright. I don't get why they always make such things black/dark as it get way to hot when in the sun. Being a backpack there a big chance it will face the sun for longer time when used.
2018-7-6
Cetacean
Flight distance : 2528264 ft
KedDK Posted at 2018-7-6 23:33
Aloha Ked,
     That is very true.  Many people forget what happens in the real world.  Black is not always best.
Aloha and Drone On!
2018-7-7
snowyowl
I gave it a try not 100% the result , I messed up air compressor wouldn't turn on
So I the pearlescent pigment and tried blowing some off but the base paint dried too rapidly.
The clear coat isn't fully dried so I placed it in storage and will check tomorrow to see how it turned out.
It's a learning process and I might just redo it all over since the pigments where 40% off.
2018-7-7
