Help figuring out why there is a long delay after taking photo (M...
1596 21 2018-7-6
dronto
Singapore
Hello
Recently for the first time when I flew my Mavic Pro Platinum, I encountered a long delay (DJI Go 4 App “circular shutter button” on my I PhoneX was just circling and circling after I took a photo) in between each photo taking during flight. At the same time, I was unable to take video either (while the shutter button was circling).
I have since cleared all cache in the DJI Go 4 App and also my SD card.
Any thoughts? Thanks
2018-7-6
dronist
Restart the app and check your ISO
2018-7-6
dronto
Singapore
dronist Posted at 2018-7-6 20:27
Thanks for your kind suggestion. I didn’t recall of adjusting the ISO during my flight but it may have been changed if the control button could be bumped easily. May I know which ISO setting could affect this slowing?
2018-7-6
AlansDronePics
Flight distance : 814751 ft
Guernsey
did you set to HDR? Perhaps by mistake. That takes time to process.
2018-7-6
Hummingbird.UAV
Flight distance : 27489951 ft
Check the speed of your SD card, faster cards perform better.
2018-7-6
dronto
Singapore
AlansDronePics Posted at 2018-7-6 21:30
Aha...thanks for your kind suggestion; it may have been possible. Thanks
2018-7-6
dronto
Singapore
Hummingbird.UAV Posted at 2018-7-6 21:34
Thanks for your kind suggestion. I used SanDisk 64GB Extreme Pro C10 UHS1 10
2018-7-6
Hummingbird.UAV
dronto Posted at 2018-7-6 21:54
That is a good card and should work.
2018-7-7
A CW
Flight distance : 13926112 ft
Typically this delay is caused by the read/write speed of the micro SD card within the drone. Pano's and HDR's take longer than a standard still. Using a more powerful card with faster speeds (like a SanDisk Extreme Pro A1, V30) should be fine.
2018-7-7
dronto
Singapore
Hummingbird.UAV Posted at 2018-7-7 06:21
Thank you for your kind info
2018-7-7
dronto
Singapore
A CW Posted at 2018-7-7 09:53
Thank you Andy for your kind info. Is there significant difference between my card with the C10 spec above with the A1 that you referred to? Good to know before I purchase another one. Bought mine at the airport duty free because it has drone logo on it.
2018-7-7
A CW
dronto Posted at 2018-7-7 17:52
C10 will work but the V30 will give typically faster speeds. Mine is 100MB/s read and 95MB/s write - it's the write speed you need to check on yours. If it's around 60-80 then it will take longer to complete the photo. So best to check the specs before buying another one.
2018-7-7
dronto
Singapore
A CW Posted at 2018-7-7 17:59
Thanks much Andy; apologize the information I provided above was from the sales receipt. I went to retrieve the card and took picture below and am happy to find out it’s the same as you suggested.
2018-7-7
A CW
dronto Posted at 2018-7-7 19:28
That's exactly what I use. So it's not the card - unless the one you have is faulty or dare I say it a fake - there are a number out there.
2018-7-7
dronto
Singapore
A CW Posted at 2018-7-7 23:33
Thanks Andy and All, I was flying tonight and no more issue. I may have touched some buttons accidentally last time. Thanks
2018-7-8
A CW
dronto Posted at 2018-7-8 05:51
Glad it's working OK for you now mate.
2018-7-8
SparksBird
Flight distance : 10731690 ft
You know what is interesting is after the firmware update the other day to .400 I was doing some testing changing the sharpness, contrast, and saturation between each shot.  Noticed a delay like what you experienced after each setting change.  However if not changing the settings between the shots then the shot was much faster like it should be.  So perhaps you were changing the settings and this is why you were seeing the delay for the time being.
2018-7-8
dronto
Singapore
A CW Posted at 2018-7-8 05:55
Thanks much Andy
2018-7-8
dronto
Singapore
SparksBird Posted at 2018-7-8 06:53
Thank you SparksBird for your kind sharing. There was a high possibility I unintentionally changed some setting.
2018-7-8
A CW
You're welcome mate
2018-7-8
dronto
Singapore
A CW Posted at 2018-7-8 22:37
You're welcome mate
Thanks Andy
2018-7-9
A CW
2018-7-9
