DMX_MT
Malta
Xamiam Posted at 2018-7-7 07:50
The portable charging station looks to require a 110v plug to run. I have a Pure Sine Wave inverter to use when I'm out and about, but it's pretty inefficient! Thanks for the advice.
Hello Dear Xamiam,
The Charging Station is both 220v/110v Compatible.
When you charge the Batteries, the Charger has INSIDE IT a Powerbank, that charges too.
So when you are Outside Flying, you can easily Land the Spark, leave the Battery to Cool Down, and put it in your Charger again. I think it charges 3 Spark Batteries while On the Go, meaning no need of Electricity Cables etc... as it will take the Power from the Internal Powerbank.
Obviously then after Charging the Batteries on the go you will need to Plug the Charger back with a Power Source to charge the Spark Batteries and the Portable Charger Power Bank again... But I think its one of the Best Accessories I have bought for the Spark.
It nice to have Peace of Mind when Charging, apart from Li-Po Batteries containing High Energy and can be Dangerous is they catch fire, its so better to have Peace of Mind when charing Spark Expensive Batteries as they cost a lot beauces ofthe Electronics they have inside - Intelligent Batteries.
Thank you Buddy !
