Mathematical equation for flyaway
548 17 2018-7-7
Walteroma
Flight distance : 218166 ft
Having this data, after the loss causes the controller to crash, it is possible to calculate where the Mavic pro may have arrived.
H 150
home speed 32.1
Travel tance 925m
time fly 03:17
battery 91%
Km traveled 683
You can calculate how many km has traveled. Considering that with the 15% battery the drone lands, how far could it be? I do not
know if you can get a formula, I can not, I trust you.
2018-7-7
DJI Paladin
Super Moderator
Flight distance : 318 ft
Our apologies for the inconvenience. May I know if you already created case about this incident? If not yet, please contact our support using this link: (https://www.dji.com/support?site=brandsite&from=nav).
2018-7-7
A CW
Flight distance : 13838848 ft
Do you know the direction after signal loss and the wind speeds too?
2018-7-7
Walteroma
DJI Paladin Posted at 2018-7-7 05:44
Thanks for the answer, I try
2018-7-7
Walteroma
Un CW pubblicato a 2018/07/07 05:54
Sai la direzione dopo la perdita di segnale e la velocità del vento troppo?
Suppongo che è rimasta la stessa, ho solo le coordinate, ma non credo che dopo l'incidente si sia spostato. Il punto indica un'altezza di 150 metri, vento zero.
Visto che sei italiano ti dico che il punto indicato si trova ad un altezza di 150 m, quindi dovrebbe stare in cielo ah ah ah, rido per il nervoso, perdere un drone non per colpa mia non è piacevole
2018-7-7
A CW
Walteroma Posted at 2018-7-7 06:07
I assume it has remained the same, I only have the coordinates but I do not think that after the crash has moved. The point indicates a height of 150 meters, zero wind.
Zero wind? That is extremely rare.
2018-7-7
Walteroma
A CW Posted at 2018-7-7 06:26
Sorry I had seen Italy, I repeat, really the wind was 0, sunny day and I assure you was 0. The fly record gives me that is 150 in height at a specific point, it is obvious that there can not be, that it's the point where he left me
2018-7-7
A CW
Walteroma Posted at 2018-7-7 06:36
OK - well good luck working that out
2018-7-7
hallmark007
Flight distance : 6153264 ft
When you say controller crashed, if this happens RTH should kick in, in 0 wind the drone should hover not continue a 32 mph.
2018-7-7
Picanoc Jack
Flight distance : 6590466 ft
A CW Posted at 2018-7-7 05:54
oh that's a real good one A CW,  that would indeed make a big difference.
2018-7-7
Picanoc Jack
0 wind mmmmm,   and at what height did he say 150 ?
2018-7-7
A CW
Picanoc Jack Posted at 2018-7-7 08:00
May be he was flying on the moon
2018-7-7
HereForTheBeer
Flight distance : 5381368 ft
the battery is rated for up to 8 miles (12.87KM) in zero wind, straight line constantly going 1 directly.   so it could be literally anywhere between you and 12KM away
2018-7-7
Walteroma
A CW Posted at 2018-7-7 08:29
I can not evaluate the wind at 150m, but I can say that on earth not on the moon, the wind was 0, if I knew I brought me an anemometer, but certainly I could not measure it up there, or I do not know if there is an indication on log
2018-7-7
Walteroma
HereForTheBeer Postato alle 2018/07/07 09:33
la batteria è valutato per un massimo di 8 miglia (12.87KM) nel vento pari a zero, linea retta che va costantemente 1 direttamente. quindi potrebbe essere letteralmente ovunque tra voi e 12 km di distanza
Perfect I know  it is very difficult to find the drone, the maximum distance set was 1  km, so I do not think it has exceeded this limit. The  question was that in the presence of wind 0, it is possible that it has  maintained this direction and has not gone beyond (1) km assigned ?. Does not take into account the initial settings? Thanks for the reply
2018-7-7
A CW
Walteroma Posted at 2018-7-7 11:08
Not for wind speeds unfortunately but even windless conditions at ground level may not continue through altitude.
2018-7-7
HereForTheBeer
Walteroma Posted at 2018-7-7 11:18
if its out of control, your 1km restriction may not apply.
2018-7-7
A CW
HereForTheBeer Posted at 2018-7-7 11:41
That's very true too
2018-7-7
