jimhare
Flight distance : 239035 ft
Hey Ronnie, Good stuff!
Yeah, probably should have been closer to 90 seconds. Basically the rule of thumb is "only the most awesome stuff gets in." That makes it easy. If you play a clip and there is a bump in the footage, start the clip after the bump and get the most intriguing part.
I noticed that in your opening shots. It stayed on the same image for quite a long time, then had a bump, then stayed some more, then you cut to almost the same shot but with the camera rising. Instead of 30 seconds of slightly-awkward you could have 12 seconds of awesome!
I rarely make a video longer than 100 seconds and that's using the most interesting and well crafted clips I have.
Great effort, especially for your first edit! |
