Wolferl
Flight distance : 23793 ft
Austria
MGW Posted at 3-7 18:19
My spark fell into a swimming pool, totally immersed in about 4' of water for about 1 minute. I had just swapped batteries and apparently failed to completely lock new battery in place. The failure occurred as the Spark was flying over the pool after takeoff and the battery fell out, both fell independently into the pool. I think that saved the Spark for now, since there was no battery in the Spark, and no shorting of the internal electronics. The battery was toast. I shook it out, blew out as much water as I could, but did not disassemble, then let air dry for 6 days in relatively warm low humidity location. No rice, alcohol, silica gel. Put new battery in, powered up, all systems are working so far. Pool water was clean, that may have also helped. I may send in to DJI support for evaluation, check to see if any corrosion developing.
You did the right thing. Patience is key here. An electronics device that took a swim needs several days on a warm and dry place to sufficiently dry out. The problem are the fine pitch connectors, where a water film is held up long time.
It is amazing how the "rice bag" BS still survives and people still believe everything that is found on the internet. Make me really crazy....
Silica is good to dry up humid air, it does NOT really help to dry out the water in connectors.
It is good to remove as much of the case as possible and use a hair dryer on low setting. If you want to avoid losing the warranty, taking apart is not an option though.
Cheers,
Wolferl |
