KedDK
Flight distance : 1133038 ft
Denmark
Eric13 Posted at 2018-7-8 13:00
I have the P4P v1 and noise reduction is hardly perceptible for me.
Also that nasty metallic grinding noise I hear the same way as before.
That prop hype is for sure not doing much for the P4P v1.
"that nasty metallic grinding noise I hear the same way as before"
If you hear grinding metallic sounds there sure is something you need to have examined, none of the two i have flying with had such sounds.
In regards to the low noise props i have some waiting going on, want them black ... but every little sound reduction would be welcome. |
