X5S gimbal doing weird things
586 5 2018-7-8
fans8aee90d3
Flight distance : 11222717 ft
Serbia
My X5s on Inspire2 doimg some weird moves after landing.
It doesn't do this only if drone fly in manual mode or don't doing any pan movement during fiight.
All is fine during flight (except some small yaw drift). Latest firmware.
Tried everything but can't solve this strange problem.
2018-7-8
DJI Tony
Hi, apologize for the inconvenience, If may I ask when did you encounter this issue? What is the troubleshooting have you done so far?
2018-7-8
Helivideo
Serbia
DJI Tony Posted at 2018-7-8 10:37
Thank you for quick reply.
It has been some time since I noticed this strange quick spins after landing.
I can't remember exactly but I think maybe more than 2 months.
It wasn't a major problem for me since it wasn't ruining my footage.
But now I have project where after flight my camera assistant must catch drone and continue to walk with it
But when I stop motors gimbal do this quick spin on some side. I think spin direction is dependable on which side drone yawed.
Tried to turn of all sensors but no help.
2018-7-8
DJI Tony
Helivideo Posted at 2018-7-8 10:57
Have you tried to calibrate the gimbal of your inspire 2?
2018-7-8
Helivideo
Serbia
Tried with gimbal calibration but it doesn't help.
When drone initialize there's message that visual positioning sensors require calibration but I think that should not be the cause for weird gimbal spins.
2018-7-8
PH2DW
Flight distance : 39537 ft
This issue has been reported by others on the current firmware. The error is seen on the x5s and the x4s. Not with the x7.
Will be fixed in the next firmware dji reported.
2018-7-8
