DJI Tony
Hi, sorry for the convenience, If may ask are you using a standard charger? If yes, It takes approximately four hours to fully charge the battery. Please do not charge the Goggles when it is powered on to ensure safety. I would suggest connecting the battery charger to a power outlet (200-240V, 50/60 Hz), however, If the issue will persist I would recommend to contact the seller for this concern so that you could possibly process a replacement for your unit. |
