Battery or hub troubleshooting
Loulouspeak
Hi,
Mavic air bought in france (june 18) work perfectly well.
Just arrived in usa, to have fun with it. But impossible to charge batteries nor with the hub, nor without it.
On the hub 2 green lights flasshes, then 1 yellow the 1 red. On the battery charging alone, 1 then 2 green lights twice then stop, and start again.
I tired with 2 batteries unsuccesfully.
I use the mavic air charger with a ac adaptator (for french to us plug).
Does anyone have any idea ?
Thanks, i am near to desesperate.
Louis
2018-7-8
DJI Tony
Hi, I'm sorry to read this, if may I ask how many batteries do you have? Did you connect the AC power adapter to a power source with 100 to 240 V, 50/60 Hz? Would it be possible if you can provide a short video of the issue via google drive or dropbox?
2018-7-9
Wachtberger
Flight distance : 261509 ft
Have you tried in a different place too? Maybe there is something wrong with that particular socket. To my knowlege (and I read this forum quite thoroughly) this problem has never been reported before and there are a lot of travellers around here.
2018-7-9
Loulouspeak
DJI Tony Posted at 2018-7-9 12:19
Hello, here is a link to a video of an attempt of a battery charging. We change location, still the same problem. Please help.
Battery charging attempt
2018-7-9
Loulouspeak
Finaly, we found the solution. We bought an AC adaptator with us plug. The problem was to go through 2 power converter one form 220 europ to us and one from us to mavic...
Never use two converters.
2018-7-10
Loulouspeak
Problem solved
2018-7-10
DJI Tony
That's great to know! Kindly keep us posted if need our assistance. Thank you.
2018-7-10
