OnePlus 6 DJI GO does not work
6521 16 2018-7-9
mannvera
Sweden
BlueTooth connected - but app crashes constantly
2018-7-9
DJI Wanda
Hello there. We apologize for the inconvenience. Have you tried to reinstall the app? If yes, can you try to use a different mobile device? Because as per checking on our website, OnePlus 6 is not compatible with Osmo Mobile. Here's where you can find it: https://www.dji.com/osmo-mobile/info#downloads
2018-7-9
mannvera
Sweden
DJI Wanda Posted at 2018-7-9 04:41
[view_image]
Hi  Wanda,
thank you for replying,
and yes I have installed and removed and installed again,
tried versions 1 , 2 , 3 , 4  older than now,
DJI Go was working  on the oneplus 6 , 2 weeks ago.  since update on android, and DJI Go
after that problems.
Have tried with Iphone 5s where DJI Go works partly, but functions like follow object doe not.
Take a look at  https://play.google.com/store/apps/details?id=dji.pilot
where you se that everyone with a newer android phone has the same problem as I.
2018-7-9
DJI Wanda
mannvera Posted at 2018-7-9 06:34
Hi  Wanda,
Alright. Thank you for the response. We'll forward this information to our engineers. We apologize for the inconvenience. Your patience will be much appreciated.
2018-7-9
Howharvey86
Flight distance : 3947 ft
I'm having the same problem. Not working with DJI Mavic air and OnePlus 6. Plug in USB and phone vibrates as if it's detected something been plugged in but it doesn't offer to open an app nor does the app recognise it when opening it manually
2018-7-12
DJI Wanda
Howharvey86 Posted at 2018-7-12 08:27
Did you try to use a different mobile device?
2018-7-13
Howharvey86
DJI Wanda Posted at 2018-7-13 07:10
Yes. Works on older device (1+3t)
2018-7-13
DJI Wanda
Howharvey86 Posted at 2018-7-13 21:28
Well, that's good to know since the mobile device that you're using is not compatible. You can double check it here: https://www.dji.com/osmo-mobile/info#downloads.
2018-7-16
aenews
DJI Wanda Posted at 2018-7-16 00:43
I have the same issue.  The DJI Go application crashes for me.  Took this gimbal with me on a trip, and it was completely useless as I wasn't even able to register the gimbal.  Registered it when I got back home, and it does seem to at least work now.  However, the phone won't even remain flat, and I did not have that issue with the previous model which supported less weight.
2018-8-2
DJI Wanda
aenews Posted at 2018-8-2 20:02
May I know what model of the mobile device are you using?
2018-8-3
djiuser_useAQR0LqmBy
Having the exact same issues with my HTC U11, anyone got a solution yet?
2018-8-28
fans26dd7c2a
I had the same problem. Connect the phone OP6 and wait for the vibrate. Open settings and go to Tethering and Network. Turn on USB Tethering It should all work. I struggled with this for a few weeks and just figured it out.
2018-9-4
DJI Wanda
fans26dd7c2a Posted at 2018-9-4 17:57
Hi. OnePlus 6 is not compatible with Osmo Mobile.
2018-9-5
JignersP34K
Flight distance : 92195 ft
Enable developer options, then enable usb debugging.
2018-9-13
JignersP34K
On your OnePlus 6 go to:
1. Settings
2. About Phone
3. Build Number - tap this several times until it says developer options enabled, then
4. Back to settings
5. Developer options
6. Enable USB debugging.
Smile.
2018-9-13
stormense8
Flight distance : 40030 ft
Sweden
JignersP34K Posted at 2018-9-13 06:36
1. Settings
2. About Phone
This is bluetooth and not USB, Your tip don't work. The solution is to purshase a brand how support One Plus 6 and others no $1000 phones with good spec. I use Osmo mobile 2 before and love it but stop woring on One Plus 6. I dont want to sell mine but it is diffuculd in Sweden because many high tech nerds have this phone.
When it woorks in old days
2018-10-27
Diegocampy
I have the same problem with One Plus 5 and Android 9.0.2
I think the problem is not One Plus, but the incompatibility of the app with Android 9 :-(   before update my Phone, djigo work find.
Is very bad for me this problem!!! any news?
Regards
2019-1-17
