bob_angie
Flight distance : 321519 ft
I've seen people use extended M4 screws from hardware stores to attach things to the side mounts. If you do this you could mount a small cheese plate or a nato rail and attach the rosette mount to that. I imagine it will look and feel as professional as you make it, the only worry will be the weight stress on those M4 screws. Seeing as it's all DIY at the moment, there's no guarantee anything will hold up, I can't imagine attaching anything to those screws will damage the gimbal, but I wouldn't recommend holding the entire weight of the Ronin-s by that handle should you attach it.
good luck! |
