pmshop
Flight distance : 8073271 ft
A few of you all have been asking me to share a tutorial on upscaling both resolution and fps.
True, most editors cannot handle such a task and just "fakes it".
However, Filmora can handle the upscaling to 4K (not cinematic letterboxing) and Sony Vegas Pro 15 can render real (not double frame) 60fps.
Sony vegas Pro 15 can also handle the upscaling.
Let's start with Filmora:
After working with your clip and you have clicked export, select mp4 and click settings.
Select the following: Quality - Best; Resolution - 3840x2160; Bitrate - 80,000kbps
Click ok then export
You can try 4096x2160 but I got letterboxes on the sides.
Sony Vegas Pro 15:
Put all clips onto the workspace you intend to use.
Select File then Properties.
In the properties box, use the drop down menu for the project you want - let's go with HD 1080-60i 29.970fps)
Then select frame rate - 59.940Click apply then OK
Right click the video clip and select properties
Make sure maintain aspect ratio is the only thing checked
Click "Conform to project Frame Rate" - NOTE! speed changes to 2x by default
Click OK.
If 2x is the speed you need, adjust the length of the clip to match 1/2 way throught the clip (new endpoint)
If you want regular speed, open the clip properties again and change the playback rate to 1.000
Once the editing is done, click render
Select the mp4 file type.
There you locate the project resolution and frame rate you selected.
There were three selections on each resolution and frame rate.
This should be normal computer, video card 1 assist and video card 2 assist.
Choose what you wish.
After selecting the rendering frame rate & resolution to match project framerate and resolution.
Choose the location to save the file and click render
This will also work for 4K60
Just play around with your editor if you do not have these editors.
That is how I stumbled across the 60fps
And for the doubting Thomas out there... please examine this 60fps clip to your satisfaction:
https://drive.google.com/open?id ... LpBQI2_VIuNDsj9hZdI
preview in Google Drive will be reduced to 1080 but if you download, you will see the quality.
Any question, let me know
Credit to user Northwood Mediaworks for having me poke around at Vegas Pro 15 to accomplish this
