KedDK
Flight distance : 1133038 ft
Denmark
Is it a new purchase? - then return it where it was bought for a replacement.
As Mark say you can try cleaning the terminals on both Battery and in the aircraft, it would be the first one on each side that transmit the data signal, but it might as well be a fault in the aircraft.
Do you have more than one battery you'll know if it is the battery or the aircraft that has the issue, being flying one myself over the winter i am well aware of the excitement each time the battery status update only to freeze again for unknown time.
I don't know why Wanda want a screenshot, it will give no more clue to see a picture than cite the error message like you did, guess it would look not much different than this one.
