FAAtest.com UAV
Mark The Droner Posted at 2018-7-10 02:10
One other thing - be wary of Class E airspace. Re Cetacean's latter example, if you're anywhere near a medium sized airport, check the sectional chart and be sure Class E controlled airspace doesn't start at 700 feet. Obviously, you can't enter that without FAA authorization. It may start at 1200 feet too, depending on the airport and your proximity to it. Airmap won't help you because it assumes you're dutifully flying at 400 feet max. The sectional will tell you what's going on.
http://www.boldmethod.com/learn-to-fly/airspace/class-e/
Mark, your message can be interpreted in various ways, some of which are correct and some of which are not. Unfortunately, there's a lot of blatantly wrong information on this topic out there, including much from forums and fly-by-night online drone "universities" and similar sites.
The key question that many budding and certified drone pilots cant seem to get their head around is this one:
"Is ATC authorization required to operate a drone under Part 107 in all controlled airspace in the USA?"
The answer to this question is NO, it is NOT.
The relevant regulation is from AC 107-2 5.8:
"Though many sUAS operations will occur in uncontrolled airspace, there are some that
may need to operate in controlled airspace. Operations in Class B, Class C, or Class D
airspace, or within the lateral boundaries of the surface area of Class E airspace
designated for an airport, are not allowed unless that person has prior authorization from
air traffic control (ATC)."
So, clearly operation in all of the above listed pieces of controlled airspace requires ATC authorization. But this is NOT the full extent of controlled airspace in the USA.
Specifically, there are (at least) two cases that fall outside the above:
- Class E airspace to the surface which has NOT been designated for an airport (but instead has been designated for an airspace extension)*
- There is no ATC authorization to fly in class E controlled airspace not associated with an airport, as long as all other regulations are met. For example, if a 400 foot tower exists in airspace that is class G to 700' AGL and then class E 700 AGL and above, operations above the tower IN CLASS E (CONTROLLED) AIRSPACE are permitted without further ATC authorization at, for example, 750 feet AGL.
That said, 107-2 also states:
"Those planning sUAS operations in controlled airspace are encouraged to contact the FAA as
early as possible"
If you plan to fly in ANY controlled airspace, regardless of ATC authorization required, you are "encouraged" to contact the FAA anyway.
As 107-2 is written and as quoted above, especially with the second example, it is clear that it is not the case that ATC authorization is "always" required for controlled airspace. Unfortunately, FAA documents themselves are often ambiguous and contradictory, especially when the FAA makes "quick reference guides" and such a lot of the nuance, but the above from 107-2 is pretty definitive.
** PLUG: if anybody out there is interested in a reasonably priced drone test prep from actual aviation professionals rather than the latest fly-by-night expensive online drone 'school', please give Dauntless Aviation's groundschool apps a look. This particular question is dealt in more detail there along with several illustrated examples. we routinely get feedback from users who have been misled by other preps who are great at marketing but not so good at the content. we have over 5000 actual and representative FAA UAS questions with full explanations. While of course we make errors too sometimes, the difference between our stuff and that made by others is pretty clear. **.
* there is slight ambiguity in the reg with regard to this, but this interpretation seems to be most correct. people can legitimately disagree on this and a definitive FAA ruling / legal letter would be good. It is worth noting that a LOT of the drone regs are quite poorly written and have ambiguity.
