AlansDronePics
Flight distance : 814751 ft
Guernsey
Everything will be on the SD card in the drone, so why not just look there?
Copies of stills and video on the viewing device is a nuisance, unless you lose your drone, so they can be switched off if you research for your device.
My routine is:- Copy SD card to 4GB external hard drive when I return home. I rename and date the file, for example, Fort Tourgis 11-7-2018 This is the master store.
From there, I copy the shots I need to the computer in a suitably named file and edit. 4K video will seldom run smoothly from peripheral storage.
There is a backup store as well. Once its gone, its gone!
