I shot a couple 360 photos and all of them stitched with these horrible green lines throughout the frame. They show up when put into any 360 software such as skypixel aswell. Any idea what im doing wrong?
Ive shot 360 photos with this before and theyve worked fine.
looks like lens flare that's been stitched into the pano, maybe try tilting the camera down slightly before starting the capture or get a sun shade for the camera
DonB1 Posted at 2018-7-11 02:51
I found that on one of my photos, it appears to be the rotors reflecting the green front leds of the MA for some strange reason.[view_image]
Ahhh ok that seems like that might be it. Any idea why its having issues stitching tho...as in I can see you got a weird reflection of the land in the right of your photo. I also had the lake in the right of my photo show up twice.
BoXiS Posted at 2018-7-11 02:56
Be sure your LEDs turn off automatically when shooting pictures, if that is the case.
There is option for that in settings.
Yeah that seems like it might be part of the problem. Theres still a sticking error tho...the lake to the right of the photo.
If the photo doesn’t has enough overlap image area or the image pattern can’t be match with other photo stitching error will occur. Water surface, single colour surface and repeated pattern are not working well with stitching.
sheamac Posted at 2018-7-11 21:05
Try to stitch the separate pictures manually in some software (Microsoft ICE f.e.) to see, if the end result is any different.
I have problems with the panos having blurry intersections when coming directly from the Air, but when stitching them later on PC they are sharp.
