calibrating the compass
2387 13 2018-7-11
fans5d4db3ea
videos showing how to calibrate a compass show a horizontal 360 sweep of the mavic and then some show a vertical 360 sweep or a sideways mavic 360 sweep.  Which one is it??
2018-7-11
Fraggboy
Flight distance : 81401 ft
You always want to start with the vertical 360 degree sweep and then change it to sideways when prompted on the screen.
Sometimes you will go past 360 degrees.  Don't change orientation due to you going in a complete circle.  Keep going until it changes on the screen.
.. Look at the orientation showing on the screen.
2018-7-11
DJI Paladin
Flight distance : 318 ft
Hi there, thank you for reaching DJI forum. Please check the instructions below.
* Go to the DJI GO app > Camera View > Aircraft Status Bar (top of the screen).
* Next to "Compass", tap Calibrate.
* The Aircraft Status Indicator will change from flashing yellow to solid yellow when the aircraft is ready for compass calibration.
*Hold the aircraft upright and rotate it 360 degrees along the central axis.
*Hold the aircraft with its camera facing down, and rotate it 360 degrees along its central axis.
*The Aircraft Status Indicator will change from solid green to flashing green when calibration is complete.
2018-7-11
A CW
Flight distance : 14177772 ft
And ensure to rotate counter-clockwise.
2018-7-11
B1houdini
Flight distance : 927927 ft
When in doubt I looked for instructions on YouTube.
This one is good at  explaining
2018-7-11
HedgeTrimmer
Here is a video showing the three ways to calibrate the Mavic compass.
Do note, that compass calibration needs to be done outside, and at least 10-meters away from possible sources of magnetic field interference (aka cars, metal buildings, bicycles, power lines, etc.) and you should not have any magnets or magnetic material on or about you.
2018-7-11
HedgeTrimmer
A CW Posted at 2018-7-11 09:27
What if you are South of Equator?
2018-7-11
Picanoc Jack
Flight distance : 10411017 ft
I don't know if anyone has told you but you don't have to calibrate the compass everytime you fly.
2018-7-11
A CW
HedgeTrimmer Posted at 2018-7-11 12:12
Hahahahahaha
2018-7-11
fans5d4db3ea
i'm still confused...all videos show a horizontal rotation first but the second one some videos show the mavic straight down (camera facing down), others show it on its side.  To make matters worse, some show rotating clockwise and others counter clockwise!!  Which is it?? This cant be that difficult to all be on the same page, right??
2018-7-12
HedgeTrimmer
fans5d4db3ea Posted at 2018-7-12 06:08
I always follow direction of rotation shown on GO-4 app screen.
Also do calibrations well away from any source magnetic interference.
2018-7-12
A CW
Straight down, counterclockwise and as Hedge said
2018-7-12
3-D
Flight distance : 635764 ft
I understand the question.
The app used to start with the the aircraft horizontal, and then move to vertical.  The directions were very clear, and the images matched the verbiage.  Then with the 4.2.14 version of the app, the image changed.
Now, the first portion is the same but on the second portion, the image shows the aircraft on it's side, not with the nose facing down.  The verbiage is still the same though.
I have tried it both ways, and it has worked both ways.     So I don't know what the true method should be, but what I normally do is horizontal for the first turn, then vertical (nose down) for the second.
2018-7-12
fans5d4db3ea
3-D Posted at 2018-7-12 07:13
thanks! I'll stick with that method too.
2018-7-12
