Crio
Flight distance : 67713 ft
hallmark007 Posted at 2018-7-13 00:58
Just a quick look at your log, although speed shows as high as 54mph, I beleive this might not be correct, when speed readings shot up you were descending full 100% throttle down, now if you look at your descent, you are coming down at a very normal rate of descent and this doesn’t match up to the high speed showing, I would have expected a much faster descent if Aircraft was at 54mph. So I definitely would say this is some blip with speed readings.
As for the sudden move, I would sync your flight and ask dji engineers to take a look.
Yeah it would be good idea as this LOG is only from live feed...
Considering I wasnt there alone flying that time in this location. We were flying there for almost 3h without a single high wind warning ( except the one when MA got while speeding ) . Conditions were checked numerous times on different hights, 12mph gusts was the strongest I've registered that evening, so if it was the wind my Air had to be extremely unlucky to have a single gust ( never to seen again ) focused on it and be strong enough to make it act like this.
There is also something that doesnt apper in live feed...
I had some warnings from motors too, they are not present in the log ??
