Appalachian Aerials
DJI Tony Posted at 2018-7-18 13:59
Hi, I would like to clarify, did you manage to use the DJI assistant 2? if the issue will still persist, I would suggest sending the unit to our facility for further evaluation. Thank you.
What, so I can wait four months to get back somebody else's broken drone? No thank you.
As for DJI Assistant 2, it says that I'm ont he most recent firmware, which matches the app.
EDIT: So as is, my gimbal is mostly pretty stable, but if I've been turning it will slowly yaw back the opposite direction when I stop turning, it can't handle faster speeds (and I'm talking Position Mode, not Sport Mode), it's much more likely to drift/tilt if I move forward while it's doing that automatic yaw, and I can see little shakes in the camera that would cause jello if I didn't have an ND filter
With that in mind, do you have a recommendation of which firmware might get me the most stability? From reading the forums and from my own experiences, I'm pretty sure that your company just has a nasty habit of manufacturing drones with bad cameras, but I'm not going through the hell of customer service.
