Lightbridge Pixilation of image on iPad
1116 4 2015-5-20
richardhuison
Flight distance : 54455 ft
Hi Folks,
LB fitted to a S1000 and using the GH4. Everything set up great apart from two probelms.
1, Air bridge has the green LED for Control but the RED is also illuminated indicating no Video.
2, The LB is sending Video to teh Ground station and i can view it on the iPad Beta app. but it gets Pixilated.
Everything is up to the latest firmware and i changed the HDMI cabel to the GH4 thinking it was that but still getting the problems
Any advice?
2015-5-20
DJI-Cathy
1. when you use HD Gimbal, the video is red at the LB air end when it is working, that's normal
2. set the Transmission Mode to Realtime or Smooth mode to see if it helps
2015-5-26
richardhuison
DJI-Cathy Posted at 2015-5-26 17:17
2. s ...
Hi Cathy,
Im glad that the Red LED is normal. And i set the Mode to Realtime and that seems to be the best quality, Smooth mode is worse and HD is really bad.
2015-5-26
DJI-Cathy
richardhuison@y Posted at 2015-5-27 00:33
Hi Cathy,
Im glad that the Red LED is normal. And i set the Mode to Realtime and that seems to be ...
Do you have any Gopro which can connect the LB air end directly? if so, please check whether you have the same pixilated
2015-5-26
richardhuison
DJI-Cathy Posted at 2015-5-27 09:39
Do you have any Gopro which can connect the LB air end directly? if so, please check whether you ha ...
After the help from Cathy, she was spot on with her advice. It turned out to be a faulty GCU cable. It's picture perfect
2015-6-10
