JuriV
Hi there,
Have been scrolling through this thread and found I have the exact same problems as other users with Sony Alpha (A7iii and Riii). IMHO DJI should fix this in communication with Sony.
Anyway, THE SOLUTION TO THIS PROBLEM, I found after testing is this: use a camera cage on your camera (such as the smallrig camera cage). When it is on my camera the motor noise is down to a minimum. Also, I recall that DJI says in the manual to use the riser plate, that came in that nice Ronin case. So maybe, that works too, any of you tried that? I think the vibration of the camera that causes the Ronin-S motor noise is somehow absorbed by the camera cage, and maybe also the riser plate.
Still, it’s a weird problem |
