Green Gimbal Mode Not Working
683 2 2018-7-13
fans58dd7085
Sweden
Hi!
While in Yellow gimbal mode everything is working just fine, but clicking the power button once, changing the mode to green, the phone is turning left to right, but not up and down....the up and down movement is just as in yellow mode, so i can't film up and down.....just straight ahead. It did work in the beginning, but it just stoped working for some reason.
How can I fix this? Is there anyway to do a factory reset?
/Niklas
2018-7-13
fans58dd7085
Sweden
Im almost certain that I tried the " Pitch Lock", with no result. But now when I turned  Pitch Lock off, it's working as it should again. :-)
2018-7-14
DJI Wanda
Hello there. We apologize for the inconvenience. Did you try to calibrate the gimbal?
2018-7-16
