Mirek6
Flight distance : 609724 ft
Dajones Posted at 2018-7-14 10:45
This has not happened before, the drone is just over a week old had no crashes or knocks, always landed with holding the throttle stick down.
The issue has not happened today so hopefully it was just a bad area/moment.
Dajones,
No, this was not “just a bad area/moment”.
I have seen tens of cases like yours. As a matter of fact, you did answer your own question of what happened by admitting that software instructed you to calibrate compass when you moved to a different location. Your case is all about uncalibrated compass.
Vast majority (not all – but vast majority) of compass/yaw errors followed by dropping to ATTI are caused by poorly calibrated compass and/or poorly calibrated IMU. As DMX_NT suggested in post 5, yaw errors are caused by different reading between compass and IMU. If Spark does not detect clear compass errors but readings differ, it will throw yaw error. However, if compass and/or IMU are badly calibrated and Spark gests confused, it has propensity to throw all kinds of errors in sequence – compass, yaw, speed, weak GPS etc. This does not necessarily mean that everything is bad, it just means that Spark is confused. Usually, following such confusion and to avoid toilet bowl effect or start flying in wrong direction, Spark drops to ATTI. This is correct behaviour.
Magnetometer (compass) can get un-calibrated by variety of causes. The most obvious is travelling long distances from the last geo-position where you calibrated it. Three-dimensional properties of geo-magnetic field may differ from location to location throwing magnetometer calibrated in other location off. But there are many other causes. Perhaps you had some sources of electro-magnetic interference in your car which could un-calibrate you compass. Maybe you stored Spark in some location where it was subject to some forces which had detrimental effect on its calibration? There are many scientific articles you can google which explain magnetometers in detail. Even without any interference, magnetometer may lose its calibration over time. As a matter of fact, DJI does recommend calibrating compass if you did not use Spark for over 30 days or if you move more than 50km from the location you calibrated it last (this recommendation is not in Spark manual but is in Mavic Air manual – very similar if not same magnetometer technology. Besides, DJI Tony just confirmed it in his post above).
In addition, first thing to do after you experience any yaw or compass errors during flight is to calibrate both compass and IMU. It does not matter if DJI GO app prompts or does not prompt you to do it. Compass/yaw errors are clera sign of trouble. DJI GO app is buggy and DJI replaced many a drone lost because of this exact problem and pilots not being aware of it becasue everything showed normal before flight. Use your head and knowledge – do not trust 100% what software says.
However, in your case, software was correct since it prompted you to calibrate compass.
One more thing – do calibrate IMU as well. Just additional insurance policy.
For everybody reading this. I will not repeat compass calibration procedure - it has been posted, videoed and described many times. What has not been described and is missing from most instructions is the fact that you should do it slowly. Turn your Spark very slowly on both axis. Never rush. You may want to turn it twice (720 degrees – not only 360). Magnetometer reads three-dimensional geo-magnetic fields – allow it to do it properly.
Dajones – I am confident your Spark is just fine. At least for now :-)
Mirek
