Shalabid
Flight distance : 31726 ft
Russia
Hi everyone, I'm new here and I hope you can help me.
Last week I was flying my spark. Probably a minute before take off, and 15 m away and 51 m height, the drone suddenly disconnected. At first I thought it was just the normal thing (despite it was pretty close and with the RC). I was flying over a river, and I started noticing that the drone was slowly losing altitude. I was trying to gain connection again but it wasn't working, and of course pressed the RTH button several times with no effects. I opened the app again and nothing, the drone simply lost connection. It stopped descending 50 cm above the water, so I thought I may have aprox. 13 minutes to figure it out since the battery was fully charged. But a few seconds later it kept descending until it finally sunk in the river.
There was evidently no pilot error, and as I said the return to home didn't worked when drone disconnected. I sent a message to DJI and they responded:
Dear Customer,
Thanks for your patience.
For your case CAS-2002522-B5L5X8, we have finished the data analysis, and the result is as follows:
1. The aircraft worked in GPS mode in the flight;
2. The aircraft flew back and ascended after the pilot pulled back the pitch stick and pushed up the throttle stick, then the flight record ended at t=00:38, h=51 m, d=15 m.
The record ended without any sign of abnormality, so we could not verify what happened afterward.
We truly appreciate your support for DJI. If you could not recover the product and would like to purchase a new one, we can offer you a 30% off coupon for a new Spark(Alpine White).
That's it. That's their response. Of course they can't know what happened next because the drone lost connection. From the flight record you can see that it lost connection when flying over water. Of course I couldn't get it back because I'm talking of a big European river, impossible to find it (and probably illegal to try to dive in).
I don't think that a 30% discount is fair, I actually think it is abusive. "We sell you a horrible drone and if it fails you can buy next one 30% off. "
What should I do? Thanks everyone!
