Replacement motors?
1616 8 2015-5-20
pluhn
Flight distance : 55607 ft
Does anyone know if a replacement motor for the Phantom 2 will work with the 3? I had a run in with a tree and now one of the motors has a burning smell and won't turn on. I know know available parts are slim for the 3, so I'm hoping the motor is the same as for the 2...
2015-5-20
raiedzeidan
Flight distance : 755033 ft
Not the same motors.
2015-5-20
taoye.blue.gmai
Flight distance : 717172 ft
It is 2312 KV960 motor, the same as the later version of P2.
2015-5-20
pluhn
I ordered a 2312, so I'll report back on Friday once I receive it and test it out.
2015-5-20
lebed73
Flight distance : 2922999 ft
United Arab Emirates
Gents, hi.
i also just found trouble with CCW motor at my P3.
this is noising when i rolling him.
i think that problem with bearing and I need replace him.
can you advise me about type or number for order this motor?
thanks.
2015-6-2
Daninho
Flight distance : 70203 ft
lebed73@mail.ru Posted at 2015-6-3 02:22
Gents, hi.
mine did the same right out of the box and i send it to the service center. You will definately loose all warranty when you solder a new motor in and open the Phantom. I wouldnt do that at all because the phantom3 is a new copter and it can fail for other reasons and then you are doomed
2015-6-2
lebed73
Yes, its clear. but, maybe me local dealer can replace this motor. anyway, I need to be sure and need to know motor spec and number as well.
2015-6-2
lebed73
pluhn Posted at 2015-5-21 11:18
pluhn, hi.
after replacement, share your your experience with me.
is it fit or not.
2015-6-3
lebed73
Guys,
any updates with motor replacement?
2015-6-15
