GH5 will the Ronin S follow focus work with adapted lenses?
2736 12 2018-7-15
Conner Murphy
I have a GH5 and am thinking of purchasing the Ronin S. I have a native mount, focus-by-wire lens (20mm f1.7). I was wondering if putting a speedbooster on the GH5 would allow me to use compatible Canon lenses on my camera with the follow focus?  Thanks!
2018-7-15
Jesaul
There were reports on ecternal sites that it works. I'll be able to check that at the end of the month.
2018-7-15
rigo-dritto
does it works with Viltrox Ef-M2 and Gh5 ????
Thanks
2018-12-19
fansa605563a
Flight distance : 11778 ft
rigo-dritto Posted at 12-19 06:47
Thanks
I'm using the GH5 with Metabones .64 and Sigma 18-35. It works most of the time. Ronin-s and the GH5/S is not fully compatible due to the issues with the follow focus and rec/stop button continuing to stop working after about 5 min and sometimes less
2018-12-19
Jesaul
It works with speedbooster and Tamron 24-70, Tokina 11-20
2018-12-19
rigo-dritto
fansa605563a Posted at 12-19 20:42
I heard that with GH5 it stops working if you use an external monitor. And anyway I know that they are working on a firmware to correct. Viltrox is similar to Metabones, has the same automation, so I think I work well with Viltrox
2018-12-22
rigo-dritto
Jesaul Posted at 12-19 23:09
Thanks, so I hope you work well with viltrox and Canon lenses
2018-12-22
fansa605563a
rigo-dritto Posted at 12-22 08:50
This fixed my issues with using an external monitor. I use it for push to focus and start/stop record along with the external focus motor for zoom on the sigma 18-35
https://store.dji.com/product/ro ... cable-for-panasonic
2018-12-22
rigo-dritto
fansa605563a Posted at 12-22 15:22
https://store.dji.com/product/ronin-mx-rss-control-cable-for-panasonic
but did you install the external follow focus Servo? accessory apart? or not?
2018-12-23
fansa605563a
rigo-dritto Posted at 12-23 03:47
I use the external follow focus to zoom with the Sigma 18-35 attached to a metabones .64. You can also use it for focus too. With the new wire I had no problems with the record/stop button not working. I recorded for about 1 1/2 hours.
With the external follow focus you don't need the usb c cable and ou don't run into the black screen issue when using an external monitor.
2018-12-23
fansa605563a
2018-12-23
rigo-dritto
fansa605563a Posted at 12-23 06:27
However, I do not use external monitors and only use fixed optics, so NO zoom. My question is: using fixed optics and Speedbooster, with the USB cable, can I adjust the manual focus directly from the gimbal without using an external motorized servo focus? Thank you
2018-12-24
Jesaul
Yes, you can. I use the existing wheel with speedbooster.
2018-12-26
