Lamplighter55
Flight distance : 538596 ft
DJI Tony Posted at 2018-7-17 11:47
Hi, sorry for the inconvenience, for clarification, once you updated the drone via DJI Assistant 2 the aircraft should be updated, however, I would like to ask if you manage to update your remote controller as well? Did you try to update it using the DJI GO 4 app?
Hi Tony, I first updated my Mavic Pro Platinum using the latest build of the DJI Assistant 2 (Mac OSX version). Then 2 days later when I plugged in my Crystalsky monitor and had updated it's firmware - when I then plugged in the remote controller and started the MPP with a fresh battery, the firmware notice came up as the GO4 app on the Crystalsky started the usual checking as it connected to the MPP via the remote controler. So I then shut down the MPP, remote controller and Crystalsky before trying the update as I knew I had already updated the firmware via the Assistant a few days before. So I then tried starting up again, but this time using my iPhone 8 IOs device connected to the remote controller. This time again the Go4 app put up a notice saying the firmware on the MPP needed to be updated. So just to check - I shut everything down again and then plugged the MPP into my Mac again via direct USB cable, and starting Assistant 2 again - and it showed the firmware was up to date. So I tried again using the Crystalsky and again the firmware update notice appeared, so this time I proceeded to install the update again. The update completed without any issues, and I then could use the MPP as usual. |
