Alle_Mors
Flight distance : 1650 ft
endotherm Posted at 2018-7-18 02:24
I wouldn't just leave it as it is. There is obviously a problem, like a broken motor wire inside. At the moment the wire is touching and completes the circuit. However during flight, with a little bit of vibration it is likely to come loose. It will crash, potentially hurting someone. Not worth it. Get it checked and fixed before flying.
I've already bought a new motor and I will try to fix it, hoping that the problem is in the motor and not in the motherboard. obviously I won't even try to take off because the drone isn't able to at the moment.
thanks for your reply
