Flying over or in the same area as power lines and a substation
841 6 2018-7-16
lgood
I'm still new to this, flying a P3 Standard, but having fun. We have small substation within 100 yds. Is that close enough to cause interference? Also how about flying above power lines. There are some in my area that are easier to fly under. I just need some guidance on how close is too close to power supplies. Thanks for the replies in advance
2018-7-16
DJI Stephen
Hi. Welcome to DJI Forum and thank you for the inquiry. As much as possible you need to avoid those powerlines. Those powerlines can affect the performance of the Drone while on a flight and this can cause severe damage to your Drone.
2018-7-16
Mark The Droner
Flight distance : 2917 ft
Power lines do emit EMF, but I've flown over them very close and have never had a problem.  Good luck
2018-7-16
Montfrooij
Flight distance : 2560453 ft
No problems here with the MP and power lines.
2018-7-16
Labroides
Flight distance : 9991457 ft
The effects related to powerlines depend on the current they carry but with even the highest current lines your Phantom will not be affected at 50 metres.
2018-7-16
Hellsgate
Flight distance : 1991555 ft
There is more danger from flying into them than there is from emf interference
2018-7-16
lgood
Thank you all for the replies. Learning more each time. Thanks again.
2018-7-16
