Battery on charge - flashing 1st LED
6484 8 2018-7-16
scmedia
Hi
I just bought my Mavic air and put the batteries on charge. Drone battery while on charge is blinking the 1st LED ( from left to right) - it was on charging for more than an hour and is still the same.  Is this a problem with the battery ?
I am suspecting this is a faulty battery because i cannot turn the drone on ( I am doing corectly, press once and 2nd time hold - not turning on)
Please help.
2018-7-16
MavikMatt
Flight distance : 660092 ft
Check the manual - sounds like the batt needs a firmware update.
2018-7-16
DJI Stephen
Hi, I am sorry to know that you are having an issue with the batter of your new DJI Mavic Air. May I know where did you purchase the Drone, please?
2018-7-16
scmedia
DJI Stephen Posted at 2018-7-16 13:40
Hi, i bought it from  retail store 'Saturn' in Vienna, Austria.
2018-7-16
DJI Stephen
scmedia Posted at 2018-7-16 13:43
Thank you for the information. Have you tried updating the firmware of the intelligent flight battery?
2018-7-16
scmedia
DJI Stephen Posted at 2018-7-16 13:52
Can you tell how to do that, since i cannot switch on the drone ?
2018-7-16
DJI Stephen
scmedia Posted at 2018-7-16 14:02
Thank you for the quick reply. Since this issue is happening the best thing you need to do is to go back to the store and ask for a replacement for the intelligent flight batter that you have. Just in case you are not able to go to the store you can send an email to our DJI Support team at support@dji.com for further help. All you need to do is to send an email containing the issue that you are facing today.
2018-7-16
scmedia
DJI Stephen Posted at 2018-7-16 14:11
Thank you for the quick reply. Since this issue is happening the best thing you need to do is to go back to the store and ask for a replacement for the intelligent flight batter that you have. Just in case you are not able to go to the store you can send an email to our DJI Support team at  for further help. All you need to do is to send an email containing the issue that you are facing today.
thanks. I will go to the store tomorrow.  Can you please help also to understand the battery lights,  ( i could not find much information in the manual), for example how is full  /empty  /  charging correctly ?
2018-7-16
DJI Stephen
Thank you. I will be posting a link where you can find additional information about the DJI Mavic Air's intelligent flight battery. I hope this can help ( https://dl.djicdn.com/downloads/ ... 20Manual%20v1.2.pdf ). Please see pages 29, 30, and 31.
2018-7-16
