400 FT
14617 14 2015-5-21
mgstalder
Flight distance : 856650 ft
Can you explain the 400 Ft elevation limitation to me in more detail?
i have interest in shooting a valley with mountains on one side of the target area.
if i take off from the top of the mountain i assume i could go 400 feet above that point.  however, what happens when i move from above the mountain to the valley (say 600 feet below)?  will the drone automatically drop to 400 ft above the valley?   if so, what happens when i want to return to land?  in otherwords, what is the 400 Ft. calcualtion based upon?  the location of the controller or the actual drone?
thanks in advance,
2015-5-21
iSkyUnmannedSys
Flight distance : 7152087 ft
400ft AGL, or Above Ground Level is a standard measurement for pilots. So you are correct when you say you can be on top of a mountain and go 400ft above your take off point as that's the key thing, 400ft AGL.
Think of an aircraft flying down a valley at 500ft AGL, which is the minimum as a general rule, could be 400ft above the valley floor but have 2000ft mountains on either side of him, but he's 500ft AGL in the valley.
2015-5-21
Fred D
Flight distance : 56184 ft
I believe it's 400 meters, I have flown out over cliffs where I took off above the valley and had no problems. If you go below the point you took off from, your altimeter will read negative numbers but it won't effect flight. RTH will go to what ever height you set ABOVE where you took off. in my experience anyway
2015-5-21
Scotflieger
Flight distance : 26875098 ft
Fred D Posted at 2015-5-21 20:30
I believe it's 400 meters, I have flown out over cliffs where I took off above the valley and had no ...
The 400 ft AGL (120m AGL) rule is that imposed by the UK CAA aimed at keeping RPA a 100ft below the minimal operating height for manned aircraft (500ft AGL).
2015-5-21
Rbimd
Flight distance : 407710 ft
I think we need to make a clarification here. The Inspire is capable of flying 400 METERS above ground (AGL); limited by firmware. The Ceiling altitude is 4500 METERS; that is the altitude, above which the lower air density does not allow the props to make sufficient lift to maintain altitude; limited by physics. The 400 FOOT rule is from the United States FAA, and the UK CAA; you are limited by regulations. Certainly there are mountainous areas where the minimum safe altitude for aircraft is much higher than 400 feet AGL because of surrounding terrain. I think you might consult the appropriate agency's website to try and get more details in the are you intend to fly. Permits may be needed.
2015-5-21
Ph02on
Flight distance : 75673 ft
Rbimd Posted at 2015-5-21 23:13
I think we need to make a clarification here. The Inspire is capable of flying 400 METERS above grou ...
Almost spot on Rbimd.  500 Metres AGL is the altitude cap enforced by the firmware.
Jason
2015-5-21
capalvch
Flight distance : 71125 ft
Venezuela
You cannot fly any unmaned aircraft over 500 ft agl because that is the lower limit for planes and other man driving craft. The inspire 1 limit of 400 ft agl try to avoid letting you to go over 400ft, but if you take off at the top of a mountain and drive your bird to a lower terrain, then you may be over de 500 ft limit because the inspire 1 limit is from the take off point. Then, you can be flying against the law.
2015-5-21
MGS
capalvch@gmail. Posted at 2015-5-22 08:27
You cannot fly any unmaned aircraft over 500 ft agl because that is the lower limit for planes and o ...
Ok thanks everyone.  Let me restate my question another way
Hypothetically if i were to fly my bird from the rim of the Grand Canyon over the edge - what would happen?  (There are many drops more than 400 ft).  Would the bird automatically drop to 400 feet above the canyon floor?   I can't imagine that would happen - how would i ever get it back over the edge to the rim (where i hypothetically took off from).
Tx
2015-5-21
jimhare
Flight distance : 239035 ft
MGS Posted at 2015-5-22 09:37
Hypothetically if i were to fly my bi ...
No, the bird will go over the cliff and hover there, even though there's a drop of 1000 feet it will still read at 6 feet.
You can then drop the bird down as you see fit and will have a negative altitude reading, which has no maximum so drop 1000 feet if you like.
Then climb 1000 feet and when you reach the top of the cliff your altitude will read 6 feet again.   Then you can go up another 400 feet if you like.
Basically the Inspire doesn't know you are at a cliff's edge, it just measures the difference between where you started and where you currently are, positive or negative
2015-5-21
MGS
jimhare Posted at 2015-5-22 09:59
No, the bird will go over the cliff and hover there, even though there's a drop of 1000 feet it wil ...
perfect - thanks Jim - that is what I was looking for.
2015-5-25
kmbit
MGS Posted at 2015-5-25 03:34
of course it should be said that if you were to land your bird down by the river - and take off again - that would then reset the starting altitude so not something you would want to do -  or you would be in for a long hike to get it back.   Hypothetically that is :-)
2017-1-26
Donnie Stugots
Flight distance : 3636782 ft
kmbit Posted at 2017-1-26 13:42
Just a friendly reminder that these are some really old Post you are replying to.  You may be resoponding to a member who is no longer active or the topic has been resolved.
Just a reminder from you friendly neighborhood  donnieman
donnie
2017-1-26
Coigreach
Flight distance : 546014 ft
Donnie Stugots Posted at 2017-1-26 13:47
and some really old posters... just like donnie!
I have read somewhere that donnie is a robot and replys to every post and he does not exist as a real person....lol
2017-1-26
Donnie Stugots
Coigreach Posted at 2017-1-26 18:52
don't tell anyone , It will be our secret
donnie. aka R2D2
2017-1-27
kmbit
I see that now - I will be more aware of old posts ( but I'm an old poster too )
2017-1-27
