Bluehook
Flight distance : 790814 ft
Ralphhuttonthompson Posted at 8-3 07:45
I had the same question but, litchi doesn’t know the height above ground, it only knows the height above Takeoff point. But I’m guessing the checkbox if for if u use Google Earth Pro and the Litchi Hub to create a mission using google earth terrain data. There is a video on this under the litchi hub guide. Basically u plot your mission including terrain data in Google Earth Pro, export as a .kml file then import to litchi. Now u have terrain data and your mission will be relative to the ground.
I'm no Litchi expert but I find that to be generally NOT true.
From my experience, and I'm also in a hilly area, Litchi does indeed know the ground elevation and should I tick that box, it will adjust the AC accordingly.
