Purchased my first drone, question about signal
589 15 2018-7-17
anishjoshi10
Hi Guys
Glad to let you know i've purchased my first drone DJI mavic air, picked it up for £814 for the fly more combo! Excited to get it, have read a few issues about it losing signal quite often.
Is this still an issue with many of you guys, or has recent firmware updates solved this problem?
Regards
Anish
2018-7-17
DJI Paladin
Flight distance : 318 ft
Hi there, sorry for the trouble. May I  know what firmware version, DJI Go 4 app version and mobile device your are using? Did you receive an error message on the APP?
2018-7-17
Bill B
Flight distance : 319245 ft
The only problem I had with mine in the beginning was a constant problem with disconnects. My particular issue was the crap cables that come with the MA. Once I started to connect my phone to the bottom USB on the controller, and not to the side USB on the controller, my problem has gone away, never another disconnect. Here is a video that shows the same issues I was having and how he, and I corrected them.
2018-7-17
dronto
Singapore
Congrats Anish for your new Mavic Air; Happy Droning
2018-7-17
anishjoshi10
thanks guys, its not actually arrived yet but read up on a lot of issues for people losing signal all the time so wasn't sure if it was fixed with updates etc..
2018-7-17
Woe
Flight distance : 4129268 ft
Congrats on your new bird.
2018-7-17
PdeG
Flight distance : 34019 ft
Bill B Posted at 2018-7-17 02:13
https://www.youtube.com/watch?v=5t1Lf_dxeHE
I had the same problem and I did the same, replaced the flat USB cable with a descent Anker cable, problem solved.
2018-7-17
hallmark007
Flight distance : 10017858 ft
Use this it’s great advice.
2018-7-17
djiuser_d5AB3tThUK7P
Flight distance : 10945 ft
I also have purchased my first drone. MA paid mid 800 for the combo. I've been having signal problems since day 1 I've had it not for 3 weeks. I love the drone I think it's awesome, but I can't take it further than 500ft if I do I lose signal. Really wish I could cure the problem. I am going to try another lead straight from the USB to my phone and see if that works.
2018-7-17
DJI Natalia
anishjoshi10 Posted at 2018-7-17 03:53
Please make sure to do all the steps that you need to do before you fly your drone such as; linking your remote controller to your aircraft, imu, compass and gimbal calibration, and please make sure that your firmware is all updated. If you have any other question, please let us know. Happy flying!
2018-7-17
anishjoshi10
djiuser_d5AB3tThUK7P Posted at 2018-7-17 12:40
where did you purchase it for 800?
2018-7-17
Ken Storm
Flight distance : 178583 ft
I have the MA, I have not had a signal loss yet.. I run on 5.8ghz and got about 800ft away before the signal got down to 1 bar.
I have changed to a 2.4ghz channel but as yet the wind has been a bit strong to test that.
From what I have read I should easily reach 1500ft (500m) the max range allowed under the drone code in the UK, as long as I fly high enough.
Low flying and long range don't mix.
IIRC I paid about £810 for the flymore combo about 2 months ago.
2018-7-17
Hi guys is there any other help out there for losing signal, 500ft and signal has gone, I have changed my cable to quality Anker ones and still the same problems. I've made sure everything is up to date and signal problems still the same. Really need help as this is a big problem for me and I'm stuck and can't think of anything else. It's a new MA drone only 3 weeks old
2018-7-21
Alexey Batalov
Flight distance : 21105262 ft
Try downgrading your app to say 4.2.12 for example. Download the apk from apkpure or apkmirror.
2018-7-21
G_Sig
Flight distance : 9109311 ft
Iceland
djiuser_d5AB3tThUK7P Posted at 2018-7-21 10:51
Are you using flight setting on your phone. It normally help.
2018-7-21
Zam44
Flight distance : 60958 ft
Malaysia
Wise move. Read up and go through you tube videos they help a lot.
2018-7-22
