Weird behavior (timing) in Ronin S companion app "Track" mode
754 4 2018-7-17
gilesvg
I have not tested the timing in other modes, but in "Track" mode, it seems that specifying a duration of "100 seconds" actually makes the motion transition complete in 60 seconds. This seems wrong. Anyone else experience this behavior, or can anyone else test to confirm?
Thanks
- Giles
2018-7-17
AVsupport
Flight distance : 618734 ft
I have noticed that the 'real' movement only happens once you click the 'Rec' button on the app..not the 'Play', this will only show the moves but not adhere to timing..? is that it? but, I would like shorter increments .5 secs for shorter moves...
2018-7-31
Dschapin
AVsupport Posted at 7-31 02:42
there needs to be a quick tutorial for all of this
2018-12-18
fans716d7600
Flight distance : 17306 ft
Even if you put it in rec, it does not last as long as you put it and the longer, the more difference there is.
2018-12-19
Rferrand
It is not correct how long you put and who does
2018-12-19
