Pan-Axis keeps spinning.
11342 13 2018-7-17
griffdude13
Flight distance : 53507 ft
Anyone else have this issue? I've tried resetting both on the device itself and within the mobile app. Took it apart completely, put it back together. Still having this issue.
Here's a video of my issue:
Any ideas?
2018-7-17
Alessandro Garabaghi
Flight distance : 2012457 ft
try firmware update from the dji assistant and then calibration from the assisstant
2018-7-17
StianGel
Flight distance : 686654 ft
Norway
You should try a joystick calibration.
Tap the trigger 4 times, and hold on the 4th tap. All 3 mode lights should blink, then move the joystick multiple times all over the place.
Tap 4 times and hold on the 4th tap to finish calibration.
2018-7-17
griffdude13
StianGel Posted at 2018-7-17 13:05
That did it! Crisis averted!
2018-7-17
griffdude13 Posted at 2018-7-17 13:41
Glad to know StianGel was able to help you out, besides, please make sure the firmware has been up to date. Hope you have a great time with Ronin-S.
2018-7-18
lizard force
same thing happend to me. your fix worked thanks :-)
2018-8-5
Dschapin
DJI Mindy Posted at 7-18 02:32
I am having this same problem and the joy stick calibration is not fixing it.
I have tried firmware up dates and back dates and all kinds of things and it still wont stop.
i havent even used to app  accept to open it
2018-12-17
Dschapin Posted at 12-17 01:57
Hi there, we have replied your own thread, please keep us updated there, we will keep following up, thank you.
2018-12-17
fans01387528
DJI Mindy Posted at 2018-12-17 19:12
Im having this same issue. Did you ever find a solution?
2019-1-15
fans01387528 Posted at 1-15 10:55
Hi there, sorry for the difficulties that you experienced, please make sure the firmware has been updated to the latest version, and then try the Auto Tune after physically balancing the gimbal. If there is no luck, please calibrate the Joystick and the system and let us know if the issue persists, thank you.
2019-1-16
djiuser_amj1dnAVWdSo
India
DJI Mindy Posted at 2018-7-18 02:32
Hi dji . I am experiencing that same problem . Dji ronin s keep spinning on the pan axis clockwise on its own
Balance test - excellent in all three axis
Auto tune - done
Joystick calibration - done
Advanced calibration- done
Even tried the override calibration for motor parameters- joint angles
Nothing worked
It’s keep spinning like a crazy cat
Very disappointed . It happened on very first week of purchase . As I was first time gimble user , I thought I might not be doing things right . I was busy with work so didn’t used it much . Recently I started working professionally. Try using it for a music video . Boom
2020-9-1
India
djiuser_amj1dnAVWdSo Posted at 9-1 00:14
Auto tune - done
It Calibrated it a day before shoot , it was stable , but on shoot day it stated spinning again , cost me shoot delay expenses , had to get an alternative company gimble , he worked pretty well ,
So many people reported same problem but there was so solid solution from you guys . Mostly people tried all hacks themselves and figured out things . We expect better technical support from you !!!!
2020-9-1
djiuser_fzP7qx9zVwyp
Macao
Samething with the ronin sc. Its half a decade and no answers from dji team?
2021-5-17
Macao
It did not.
2021-5-17
