djiuser_QanrnxVQafWs
Spirytus Posted at 2018-7-17 13:59
The P4 series is not well suited for the FLIR duo. The most obvious issue is that the P4 (or P4P) camera is not interchangable with anything aftermarket (AFAIK). You'll need to build and design your own solution (3 axis gimbal, transmitter, reciever, controller) and mount the setup onto the airframe somehow without disrupting the downward sensors:
https://phantompilots.com/threads/p4p-stabilized-flir-for-under-5-000.134101/
I'm actually ok with a fixed mount for my FLIR DUO R on the P4. In hindsight, I agree that I could have settled with the P3. But if I can figure out a way to stream the feed live than I'll be more than happy. Thank you for your help, the link you shared looks promising. |
