endotherm
Flight distance : 503241 ft
I'm assuming this has something to do with something being loose inside the aircraft. On the ground, the vibrations are dampened and not sufficient to cause a problem. Once in the air, the vibration is enough to cause the problem to show up. Could you try idling on the ground without props attached, and revving up to full and see if the problem shows up under full power? You will get a bunch of error messages because the props aren't there, so you can ignore those for now. This won't simulate the real load on the motors/airframe without the prop resistance, but it is a start. Perhaps get someone to hold on to the feet and keep it grounded while you try to lift off with props attached. KEEP CLEAR OF THE PROPS THOUGH!
Can we confirm that these are genuine DJI batteries or aftermarket?
I wouldn't be accepting a brand new product like this with such a problem, especially as it is under warranty. I would definitely be returning it for a replacement. |
