Unbalanced in balance test
10586 15 2018-7-18
Magicfilm
Hello, when I autotune and then do a balance test I get back the results of yaw:excellent roll:excellent pitch: bad
What axis am I doing wrong?
I'm using a gh5 plus 40mm canon on a speedboster.
I can't seem to get this thing to do the point anywhere and stay that everyone seems to do.
Help please.
2018-7-18
Magicfilm, the Pitch axis was not balanced properly, please refer to the tutorial video below to balance the tilt axis, from 0:50 to 1:33, thanks.
2018-7-22
DrMrdalj
Flight distance : 1265978 ft
Serbia
What firmware version is on your Ronin-S?
While I used firmware 1.2... all axis ware reported as “excellent”. Immediately when upgraded to firmware 1.3... in-app balance test reported tilt and roll as excellent, while for pan reported “Pan: Re-balance needed”. I must point out that gimbal has not moved during the firmware upgrade, camera was on the gimbal during upgrade, so it was exactly the same balance in both of these tests. It seems that in-app balance test results are inconsistent - they vary with different firmware versions.
Beside his problem with in-app balance test inconsistencies, from my point ow view there is some general problem with mechanical  balancing of roll axis and pan axis, at least on two pieces  that I tested.  Roll levels to horizontal by itself on matter what I try (I am sure that balance is not bottom heavy, while it drops to horizontal even when roll is set upside down). Pan tend to get itself to several equilibrium angles while gimbal is vertical (it does not drop anyway while gimbal is horizontal).
2018-7-23
Cable111
Flight distance : 3031 ft
DrMrdalj Posted at 2018-7-23 12:37
I have the same issue and I am absolutely certain the pan balance is the best of the three.
2018-8-7
KOKS
Ukraine
Hey. Have you solved this problem? At me the same problem, on 1.2 versions all ok, and on 1,3 Pan: re-needed
2018-8-21
Nohchilife
Same here, i think its the firmware problem.
1-Android app says:
2-ios app says:
2018-8-21
KOKS
Ukraine
Nohchilife Posted at 2018-8-21 09:23
1-Android app says:
not already whether dji does not see the problem (((
2018-8-21
raphael_bellizzi
Flight distance : 757976 ft
Same problem here and also a problem with the auto center. DJI already said that they'll fix it wit hthe next update.
2018-8-21
KOKS
Ukraine
raphael_bellizzi Posted at 2018-8-21 15:05
https://youtu.be/vmHEjt_CMiA
I did not pay attention to the autocenter in my (((how long to wait for an update that will fix the autocenter and balance test?
2018-8-21
raphael_bellizzi
KOKS Posted at 2018-8-21 21:48
So apparently more people has this autocenter problem, right? I thought it was only me. I hope in the next  update they fix both problems and not only one.
2018-8-22
Nohchilife
Same here also, autocenter problem,  and Pan - re balance needed
2018-8-22
Between2tides
I'm also having the same Pan - re balance needed issue.
2018-8-23
Between2tides
Between2tides Posted at 2018-8-23 11:32
FYI – I removed the HDMI cable that was feeding the separate monitor and spent a little more time with the gimbal, which included a re-balance test. It came out perfectly!
2018-8-24
fans887af746
I have the same issue with the Pan:re-balance needed and I also confirmed it goes away with the older firmware.  However I suspect that what is causing this problem is not a firm ware issue but a weak pan motor.
I have tested all the motors by pushing against them with slight resistance.  The roll and tilt motors act normally but the pan motor give a single shudder or shock at the first bit of resistance.  I also can feel this while whip panning.  I am currently trying to get DJI to resolve it.  I don't believe its a firmware issue as I felt the same pulse from the motor in the earlier firmwares when I back dated it.
2018-8-28
fans544ab907
Flight distance : 48156 ft
Argentina
Same issue for me re need balance
2018-9-16
mnliew
Singapore
I the Pan/Pitch , Re-balance issue too ......
And when I tilt it to the right .. with the motor on I felt vibration ....
whats going on??
2018-9-18
