New Ronin-S Firmware Released (07/19/2018)
16907 16907 2018-7-19
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2018.07.19
  • Firmware: v 1.3.0.20
  • Ronin App iOS: v 1.1.2
  • Ronin App Android: v 1.1.2
  • DJI Pro Assistant for Ronin (PC): V2.0.0
  • DJI Pro Assistant for Ronin (Mac): v 2.0.0
  • User Manual: v 1.0
What’s New?
  • Added focus pulling support and autofocus triggering feature for Nikon D5 with supported NIKKOR lenses. Press halfway down on the gimbal's camera control button to use autofocus.
  • Added photo capture and video start/stop control for Panasonic GH3/GH4 using the optional RSS control cable for Panasonic (RSS-P).
  • Added selectable Camera Type in the Ronin App (version must be 1.1.2 or later) for increased camera shutter control stability when using IR. Go to Ronin App->Create->Camera Control to select the camera type when using the RSS-IR cable.
  • Optimized Motionlapse.
  • Improved the stability and image quality when taking long exposure shots in Timelapse and Motionlapse. The gimbal will no longer exit these modes when the gimbal is disturbed but pop up a notice in the Ronin app.
  • Fixed the micro stutter issue when the gimbal rotates quickly and fixed the issue where the roll axis goes off level when controlling the pan axis.
  • Fixed the issue where the correct result did not display when using the Balance Test for the pan axis. Tilt the Ronin-S sideways when performing the Balance Test so that the Ronin-S can correctly calculate the test result.
Notes:
  • Ensure that the Ronin App is the latest version when updating the firmware.
  • Leave the Ronin-S turned off and update the firmware through the DJI Pro Assistant for Ronin by connecting the USB -C port on the Ronin-S to your computer. Then proceed with the firmware update. Do not disconnect the gimbal from the computer while updating.
  • After the update is complete, unplug the USB-C cable from the Ronin-S and then proceed to turn on the gimbal.
  • If the Ronin-S is turned on when updating firmware and a camera is attached, make sure to protect the camera and lens from collision as the motors will shut off during the update process.
  • If the firmware update fails, restart the Ronin-S and retry.
  • It is possible to revert back to the previous firmware version.
  • When setting the interval time for Motionlapse, always add at least one second on top of your exposure time to allow for gimbal movement.
2018-7-19
DJIJAKOB
Flight distance : 740577 ft
Norway
Any one else having issues updating to v 1.3.0.20? I had two updates available for my Ronin-S. The first one (V 01. 02.0010) went just fine and was finished in under 1 minute. But when I try to update to latest FW I get the message: "Update fail". This comes right after proceeding to click "Upgrade". The S is charged, I've tried multiple cables and a different computer. Same issue. Anyone having the same issue, or managed to get it solved?
Help much appreciated!
2018-7-19
StianGel
Flight distance : 686654 ft
Norway
DJIJAKOB Posted at 2018-7-19 05:47
I am also getting the Update Fail message.
It is only the new firmware that is causing problems. Might be to much preassure on DJI's servers.
2018-7-19
mardarethedog
Flight distance : 406604 ft
StianGel Posted at 2018-7-19 06:54
Same here!
2018-7-19
DJI-Paul
Flight distance : 41159547 ft
Try now guys. We had an issue with the cloud server updating globally.
2018-7-19
mardarethedog
DJI-Paul Posted at 2018-7-19 08:40
Confirmed! It worked
2018-7-19
StianGel
Norway
Workes for me to now.
To bad that the update did not resolve my connection issues with my Oneplus 3T.
2018-7-19
Kune
Flight distance : 1349301 ft
Updated the Firmware. Tested with Nikon D7500 and the Focus Wheel is working with Signa LENS 35 mm 1,4G and Sigma 17-50  - 2.8.
The only thing I miss is that .. I usually magnify the image to make sure the focus is perfect, but with the ronin-s connected is not possible to do so.
About the record button ... it works as well.
Is there any way to modify the focus speed of the focus wheel?
2018-7-19
danielebarone
Nikon D800 doesn’t work!
Live view still turns off.
And now turning the focus wheel doesn’t move my 24-70 lens anymore.
PLEASE WORK ON D800!
2018-7-19
DJIJAKOB
Norway
After some time the update went fine. Thanks for the information anyhow.
2018-7-20
KSK Aerial Cinematography
Flight distance : 877041 ft
Bulgaria
I'm using last firmware and app version to my android deivce (Samsung Galaxy S5). I still receive "good "for tilt balance using my Nikon 5300 with kit lens & 50 mm 1.8. Someone else having this issue? I just want to stabilize camera. Focus is just a bonus, it's not what I need the most. At first I need some help to achieve balanced camera setup.
Any suggestions how to balance tilt axis with Nikon D5300 Kit Lens. After test now I receive "good" for Tilt axis. Is it safety to use Ronin S with "good" ?! Or must achieve triple excellent?
2018-7-20
vincelk
Malaysia
Just updated my RONIN-S to the latest firmware yesterday.
And what happened was my RONIN-S was panning very slowly on its own after I restart it after the update.
And I read a couple of comments from the forum and recalibrate the joysticks and all is good now. (stop moving already).
Anyone faced the same problem?
2018-7-23
Bulgaria
vincelk Posted at 2018-7-23 04:02
Here the same. But I fail in balancing and I was thinking it was the reason for that issue.
When run Balance test I achieve good, excellent, excellent. And yes - moving forward gimbel start rotation the cam to left or right slightly.
2018-7-23
Alessandro Garabaghi
Flight distance : 1969426 ft
i forget which axis is the first ... but moving it up and down on the pan axis might help.
2018-7-24
PsionicAL
Hello there, I have GH4 camera and i have also the RSS-P cable for the Ronin-S (i ordered it from DJI and it arrived a couple days ago). It seems that is not working when i push the REC button (Photo/Record) on the gimbal, its do nothing. But in the app --> Status-- > Device --> Shutter Controller is checked!! I dont have Sleep Mode enabled in the camera. I have the latest firmware installed on the Ronin-S ver. 1.3.0.20..  My GH4 firmware is ver. 2.7..     Can you help me please??
2018-7-26
tfmedia
I can't get Dji Assistant on my iMac ir Macbook Pro ?????
2018-7-27
djiuser_arYtg8cijZYs
Austria
Hello,
since I updated to the latest version, the Balance Test reports (Yaw: Good, Roll: Excellent, Pitch: Excellent). I did no camera adjustments or movements while, before or after the update process. With the older firmware version I got all three balance properties on "Excellent".
I see on the last point of your release notes, you fixed something on the Balance Test status report for "Pan axes" and it says "tilt the ronin s sideways for correct results". So I assume the "Yaw:Good" stands for the "Pan axes" and "Good" is not the correct test result for me now because I did not tilt the ronin while performing the Balance Test.
So can you please give any hints what exactly has to be done to get the correct test result? Which side to tilt? What angle? Maybe a picture or tutorial video.
Many Thanks
S.Munar
2018-7-27
liljana15
Philippines
I don't know how to get the dpi pro assistant for Mac to launch. Nothing is popping up once I connect my ronin s to the computer.
2018-7-31
liljana15
Philippines
Can someone make a video off how to set up the 6d mark II on the Ronin S and to get the start/stop button to work? I am so confused and need a visual.
2018-7-31
lenzwizard
Flight distance : 314406 ft
liljana15 Posted at 2018-7-31 06:19
At this time I believe the 6D MKII start/stop and focus wheel features have been added to the Ronin S firmware.  Although the 6D MKII is on the list to be added. Or at least that is the info as far as I can tell from following this forum. My kit had a IR cable included for "start/stop" and it never worked at all.
2018-7-31
lenzwizard
Also make sure you have the latest firmware update and the latest app update.
2018-7-31
DMo
I've downloaded the DJI Assistant 2 on mac, logged in and it doesn't recognise the Ronin-S. Just keeps telling me to plug it in
2018-8-6
DMo
2018-8-6
BrummieP4
Flight distance : 383999 ft
Nice, thanks DJI but when is the SONY focus-pulling feature coming?
2018-8-6
fansf9d43e11
Brazil
Can someone help me? My ronin connects with my cell phone, I put the password and it connects, but after 2 or 3 seconds it disconnects and I can not activate it. DJI support asked me to update the firmware, but unfortunately I'm not getting it either.
2018-8-7
MJ Pro
Flight distance : 390 ft
Malaysia
Same as DJI Assistant 2 doesnt recognize Ronin S. I have problem with the centre of gimbal(double tap position). The roll and and tilt axis are not centered and its really annoying to have these problem. I hope by updating firmware it will solve my problem. But now, I cant even get pass updating the firmware. Need help please anyone
2018-8-13
Andrey Guryanov
Russia
Can I find A user of Sony A7r2 version? It's not  in table about IRR control and my firmwawre in phone application is still very old. Or it's have another numeration?
2018-8-15
MJ Pro
Malaysia
Anyone know why DJI Assistant 2 dont detect the Ronin S? Did I got a faulty unit. Im also have problem with the centre of gimbal, tilt and roll are off centered. Im using windows 10 btw. I dont think windows 10 was the problem because i can update my mavic pro effortlessly
2018-8-15
lenzwizard
MJ Pro Posted at 2018-8-15 21:51
Just checking; Do you have the Ronin S turned on? When I connect for firmware updates I have it turned on and connected using the cable that came with it. I have Windows 10 and I haven't had a problem.
2018-8-16
fansc3e85909
When are you releasing the next update?
2018-8-21
edwardzamarripa
I’m having the same issue as some people with the ronin s. I plug it into the computer and no luck. the pc app just keeps showing a picture to plug it in via usb. although when i plugged it in, the computer installs a driver that says something like STM32 virtual Com port. Since that happen, Im assuming that the cable works and also that the usb port works. the pc makes that noise when you plug in a cable into it as well. but im not 100% sure what the driver was called exactly but it installed successfully. im using ronin assistant 2 v2.0. any solutions?! please help
2018-8-24
fans50c4c633
fansf9d43e11 Posted at 2018-8-7 10:02
[view_image][view_image]
I get the same issue. contacted dji and they tell me they haven't heard of this issue yet. gonna send it in this week so they can see whats the deal.
2018-8-24
HeyKyle
Where do I go to get new firmware and how do I install it?
2018-8-25
Lectrio
edwardzamarripa Posted at 2018-8-24 01:19
I had the same issue! Solved it by using the program called 'Zadig' used in this YT video:
2018-8-25
edwardzamarripa
Lectrio Posted at 2018-8-25 06:11
I had the same issue! Solved it by using the program called 'Zadig' used in this YT video: STM32 install on Windows
Holy jebus!! It works! Thanks man! You’re the best!!!!
2018-8-25
edwardzamarripa
MJ Pro Posted at 2018-8-13 15:01
Scroll down to the latest posts, I just solved the issue where the ronin s pc app doesn’t recognize the ronin s. This is definitely a driver issue and not the unit itself. Dji needs to fix the app.
2018-8-25
fansdd99abef
I followed the instructions in the video but can not get the Ronin-S to show in the Ronin Assistant software. When USB-C cable is connected to the ronin and laptop, the grip lights indicate it's charging. My battery levels are at 90%. Why is the ronin-s not showing in the assistant software? Again I followed the video instructions exactly step by step.
2018-8-26
fansdd99abef
fansdd99abef Posted at 2018-8-26 10:45
Apparently, I downloaded the wrong Ronin Assistant Version. I originally downloaded Ronin Assistant, make sure to download Ronin Pro-Assistant. Now everything is fine.
2018-8-26
diablo690
i have a problem updating my Ronin S firmware to  v 1.3.0.20... the V 01. 02.0010 updated fine but after that the DJI PRO assistant 2 is just stuck on connect the USB..
2018-8-26
diablo690
i have a problem updating my Ronin S firmware to  v 1.3.0.20... the V 01. 02.0010 updated fine but after that the DJI PRO assistant 2 is just stuck on connect the USB.. i have uninstalled/install the software and device [USB Serial Device (COM3)] but still no luck... the is no error message on USB Serial Device (COM3) in the device manager... i am also aware of the usbser.sys driver and all that, but i can't find a solution please help me troubleshoot thank you!
2018-8-26
